[gdal-dev] Instructions for a new writing driver?
Abel Pau a.pau at creaf.uab.cat
Wed Jul 5 04:17:34 PDT 2023
Hi, following instructions about creating a new driver I found that
https://gdal.org/tutorials/vector_driver_tut.html
But I need to create a driver that can also write from any vector it's own format.
So, the inverse sense of the html I found.
There is any other place I can follow any instructions to fill all function classes to create this part of the driver (the one that writes it's own format)?
Thanks in advance!
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230705/f2967f89/attachment.htm>
