[gdal-dev] Instructions for a new writing driver?
Laurențiu Nicola lnicola at dend.ro
Wed Jul 5 04:21:44 PDT 2023
I think your best bet would be to take inspiration from an existing driver, like the CSV one (which shouldn't be too different from the hypothetical SPF driver in the docs).
Laurentiu
On Wed, Jul 5, 2023, at 14:17, Abel Pau wrote:
> Hi, following instructions about creating a new driver I found that
> https://gdal.org/tutorials/vector_driver_tut.html
> But I need to create a driver that can also write from any vector it’s own format.
> So, the inverse sense of the html I found.
> There is any other place I can follow any instructions to fill all function classes to create this part of the driver (the one that writes it’s own format)?
> Thanks in advance!
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230705/6b1aa8a4/attachment.htm>
