[gdal-dev] Instructions for a new writing driver?
Abel Pau a.pau at creaf.uab.cat
Wed Jul 5 06:13:22 PDT 2023
Thanks you both!
De: gdal-dev <gdal-dev-bounces at lists.osgeo.org> En nombre de Even Rouault
Enviado el: dimecres, 5 de juliol de 2023 13:59
Para: gdal-dev at lists.osgeo.org
Asunto: Re: [gdal-dev] Instructions for a new writing driver?
(resending to list)
The CSV driver is actually not that simple to follow since it has tricks to support updates through the OGREditableLayer mechanism. The GMT one (ogr/ogrsf_frmts/gmt) might be a better start for a creation & append only driver. But basically, the only common thing with your own code will be the fact that you have to implement the 2 virtual methods of interest: OGRLayer::CreateField() ,d OGRLayer::ICreateFeature() and declare a few capabilities in OGRLayer::TestCapability()
Unless you want to implement update capabilities (if the format allows it, which is generally not the case for a text based format), it might be simpler to have 2 distinct OGRLayer sub-classes for read-only and write-only operations.
Even
Le 05/07/2023 à 13:21, Laurențiu Nicola via gdal-dev a écrit :
I think your best bet would be to take inspiration from an existing driver, like the CSV one (which shouldn't be too different from the hypothetical SPF driver in the docs).
Laurentiu
On Wed, Jul 5, 2023, at 14:17, Abel Pau wrote:
Hi, following instructions about creating a new driver I found that
https://gdal.org/tutorials/vector_driver_tut.html
But I need to create a driver that can also write from any vector it’s own format.
So, the inverse sense of the html I found.
There is any other place I can follow any instructions to fill all function classes to create this part of the driver (the one that writes it’s own format)?
Thanks in advance!
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230705/d9ac909b/attachment-0001.htm>
