[gdal-dev] [AWS-S3]Access denied 403 error when requesting gdalinfo to usgs-landsat bucket?
Even Rouault even.rouault at spatialys.com
Thu Jul 6 18:52:11 PDT 2023
You also need to specify: --config AWS_REQUEST_PAYER requester
Le 07/07/2023 à 03:37, Bang Pham Huu a écrit :
> Hello,
> GDAL 3.4.1, released 2021/12/27 (Ubuntu 22.04)
> I have this file ~/.aws/credentials  (configured by this command: aws
> configure)
> [default]
> aws_access_key_id = AKIAY.....
> aws_secret_access_key = qc2KcpImI/....
> This works fine for aws CLI command to download a Landsat-8 tiff file:
> aws s3 cp --request-payer requester
> s3://usgs-landsat/collection02/level-2/standard/oli-tirs/2023/233/245/LC08_L2SP_233245_20230510_20230518_02_T2/LC08_L2SP_233245_20230510_20230518_02_T2_SR_B1.TIF
> But gdal cannot read the file?
> gdalinfo
> /vsis3/usgs-landsat/collection02/level-2/standard/oli-tirs/2023/233/245/LC08_L2SP_233245_20230510_20230518_02_T2/LC08_L2SP_233245_20230510_20230518_02_T2_SR_B1.TIF
> Warning 1: HTTP response code on
> https://usgs-landsat.s3.amazonaws.com/collection02/level-2/standard/oli-tirs/2023/233/245/LC08_L2SP_233245_20230510_20230518_02_T2/LC08_L2SP_233245_20230510_20230518_02_T2_SR_B1.TIF:
> 403
> On https://gdal.org/user/virtual_file_systems.html, it says:
> Starting with GDAL 2.3, alternate ways of providing credentials
> similar to what the "aws" command line utility or Boto3 support can be
> used. If the above mentioned environment variables are not provided,
> the|~/.aws/credentials|
> |I even tried to set environmental variables, but it doesn't work either:|
> |export AWS_ACCESS_KEY_ID=AKIAY5....
> export AWS_SECRET_ACCESS_KEY=qc2KcpImI/....
> gdalinfo
> 403
> ERROR 14: Access Denied
> gdalinfo failed - unable to open
> '/vsis3/usgs-landsat/collection02/level-2/standard/oli-tirs/2023/233/245/LC08_L2SP_233245_20230510_20230518_02_T2/LC08_L2SP_233245_20230510_20230518_02_T2_SR_B1.TIF'.
> Thanks,
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230707/6d153504/attachment-0001.htm>
