[gdal-dev] [AWS-S3]Access denied 403 error when requesting gdalinfo to usgs-landsat bucket?
Bang Pham Huu b.phamhuu at jacobs-university.de
Thu Jul 6 20:19:14 PDT 2023
Thanks Even,
it works now with these environmental configurations:
export AWS_ACCESS_KEY_ID=AKIAY5
export AWS_SECRET_ACCESS_KEY=qc2KcpIm
export AWS_REQUEST_PAYER=requester
gdalinfo
/vsis3/usgs-landsat/collection02/level-2/standard/oli-tirs/2023/233/245/LC08_L2SP_233245_20230510_20230518_02_T2/LC08_L2SP_233245_20230510_20230518_02_T2_SR_B1.TIF
On 07.07.23 3:52 AM, Even Rouault wrote:
> You also need to specify: --config AWS_REQUEST_PAYER requester
> Le 07/07/2023 à 03:37, Bang Pham Huu a écrit :
>> Hello,
>> GDAL 3.4.1, released 2021/12/27 (Ubuntu 22.04)
>> I have this file ~/.aws/credentials  (configured by this command: aws
>> configure)
>> [default]
>> aws_access_key_id = AKIAY.....
>> aws_secret_access_key = qc2KcpImI/....
>> This works fine for aws CLI command to download a Landsat-8 tiff file:
>> aws s3 cp --request-payer requester
>> s3://usgs-landsat/collection02/level-2/standard/oli-tirs/2023/233/245/LC08_L2SP_233245_20230510_20230518_02_T2/LC08_L2SP_233245_20230510_20230518_02_T2_SR_B1.TIF
>> But gdal cannot read the file?
>> gdalinfo
>> Warning 1: HTTP response code on
>> https://usgs-landsat.s3.amazonaws.com/collection02/level-2/standard/oli-tirs/2023/233/245/LC08_L2SP_233245_20230510_20230518_02_T2/LC08_L2SP_233245_20230510_20230518_02_T2_SR_B1.TIF:
>> 403
>> On https://gdal.org/user/virtual_file_systems.html, it says:
>> Starting with GDAL 2.3, alternate ways of providing credentials
>> similar to what the "aws" command line utility or Boto3 support can
>> be used. If the above mentioned environment variables are not
>> provided, the|~/.aws/credentials|
>> |I even tried to set environmental variables, but it doesn't work
>> either:|
>> |export AWS_ACCESS_KEY_ID=AKIAY5....
>> export AWS_SECRET_ACCESS_KEY=qc2KcpImI/....
>> gdalinfo
>> 403
>> ERROR 14: Access Denied
>> gdalinfo failed - unable to open
>> '/vsis3/usgs-landsat/collection02/level-2/standard/oli-tirs/2023/233/245/LC08_L2SP_233245_20230510_20230518_02_T2/LC08_L2SP_233245_20230510_20230518_02_T2_SR_B1.TIF'.
>> Thanks,
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230707/fdbe941f/attachment.htm>
