[gdal-dev] A question of eficiency
Abel Pau a.pau at creaf.uab.cat
Fri Jul 7 02:33:45 PDT 2023
I would like to know if when we use the code of GDAL to program a driver (or whatever) in vectors (so, ogr) we can assume that we can know the number of elements we are going to import in any way or it would be possible not knowing that until NextFeature is empty (or something like that). So, there is any way to obtain this number of elements without doing a while? And in case of multielements its possible to know how many parts are there in total?
I need that to write my format (I don't explain the details cause I don't get you bored :) )
If anyone know that I'd appreciate an answer. Thanks in advance.
Abel.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230707/4ad18773/attachment-0001.htm>
