[gdal-dev] gdalinfo on large vrt takes a long time
Even Rouault even.rouault at spatialys.com
Tue Jul 18 15:23:59 PDT 2023
Can you run under gdb and break when it takes a long time and display
the stack trace ?
Something along (best with a debug build):
gdb --args gdalinfo your.vrt
run
hit ctrl-c when it takes some time
bt
Le 19/07/2023 à 00:17, William Kyngesburye a écrit :
> (sorry, my email sorting rules missed your reply somehow, just found it)
> The env var didn't help, and the vrt does have statistics.
> Pathnames in the vrt are relative to the vrt, if that might be a problem in this situation.
> I turned on CPL_DEBUG.  gdalinfo is doing whatever is taking time after GDALDefaultOverviews::OverviewScan().  The next output that appears when that's done is the list of files.  The individual files do not have overviews, and the vrt has no overviews.  When I add the vrt overviews (I disable them most of the time by renaming the over file because they're out of date), I get the overview scan message, a list of overviews with no delay, then another overview scan message that has the long processing time again, then the file list.
> William Kyngesburye
> <kyngchaos*at*kyngchaos*dot*com>
> <https://www.kyngchaos.com>
> Don't Panic
>> On Jun 8, 2023, at 6:18 PM, Even Rouault <even.rouault at spatialys.com> wrote:
>> William,
>> it might be perhaps related to the GetMinimum() call done by gdalinfo. Cf https://trac.osgeo.org/gdal/ticket/5444
>> But normally it should only try to open the first source, and not all of them. At least that's what I could confirm on a quick testing. But I do see that the CanUseSourcesMinMaxImplementations() method will stat() sources whose filename looks like a local file (obviously if that's a mounted file system / vpn thing, it will not realize it is remote).
>> Try setting the VRT_MIN_MAX_FROM_SOURCES=NO environment variable / configuration option to see if that makes a difference. If it does, the CanUseSourcesMinMaxImplementations() logic should be modified to avoid doing those stat's().
>> If that's confirmed to be linked to GetMinmum(), you may also workaround the issue by doing a "gdalinfo -stats the.vrt" (from the server) to have statistics incorporated in the VRT, then GetMinimum() should be instant
>> Even
>> Le 09/06/2023 à 00:43, William Kyngesburye a écrit :
>>> I'm writing a script that needs some info from a vrt raster, and one has thousands of files. When reading the vrt over the internet (vpn to our server) it takes a long time. I think it's looking at every file of the vrt.  What is gdal reading from the files that's not in the vrt itself? I used all the -no options and I'm not adding any other info options like checksums or stats. I just need basic info from the vrt that's in the vrt file.
>>> William Kyngesburye
>>> Don't Panic
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> http://www.spatialys.com
>> My software is free, but my time generally not.
