[gdal-dev] GDAL driver plugins on github ?
Andrew C Aitchison andrew at aitchison.me.uk
Wed Jul 19 08:55:39 PDT 2023
On Wed, 19 Jul 2023, Markus Neteler wrote:
> Andrew,
> On Wed, Jul 19, 2023 at 4:33 PM Andrew C Aitchison
> <andrew at aitchison.me.uk> wrote:
>> I would like to put a gdal driver on github *as a plugin*.
>> Are there any existing gdal drivers, or other projects that
>> depend upon gdal, already separately in github that I could
>> use as a starting point ?
> You may take a look at the GDAL-GRASS GIS driver
> (https://gdal.org/drivers/raster/grass.html and
> https://gdal.org/drivers/vector/grass.html)
> which was moved out of the main GDAL tree some time ago and is managed here:
> https://github.com/OSGeo/gdal-grass
Thanks.
That is a start, though it looks as if it is unix only.
Andrew C. Aitchison                      Kendal, UK
