[gdal-dev] how do you install and configure ogr2ogr on windows with anaconda3
Vijay Kurhade vijay.kurhade at gmail.com
Mon Jul 24 02:53:44 PDT 2023
Hi;
i have anaconda3 on my windows system;  after installing gdal i can check
from command prompt ogr2ogr --version and it returns
ogr2ogr --version
GDAL 3.6.2, released 2023/01/02
But when i try to run it on my intended dxf file I get following errors
ERROR 1: PROJ: proj_create_from_database: Cannot find proj.db
ERROR 1: Failed to process SRS definition: EPSG:4326
Am I missing setting any system variables for proj.db? Where do I find it?
Thanks in advance.
Regds-
vijay
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230724/1a38b0c2/attachment.htm>
