[gdal-dev] how do you install and configure ogr2ogr on windows with anaconda3
Even Rouault even.rouault at spatialys.com
Mon Jul 24 06:36:41 PDT 2023
Le 24/07/2023 à 11:53, Vijay Kurhade a écrit :
> Hi;
> i have anaconda3 on my windows system;  after installing gdal i can
> check from command prompt ogr2ogr --version and it returns
> ogr2ogr --version
> GDAL 3.6.2, released 2023/01/02
> But when i try to run it on my intended dxf file I get following errors
> ERROR 1: PROJ: proj_create_from_database: Cannot find proj.db
> ERROR 1: Failed to process SRS definition: EPSG:4326
> Am I missing setting any system variables for proj.db? Where do I find it?
Maybe your environment is a bit messed up. Normally the PROJ_LIB /
PROJ_DATA environment variable should be automatically set up.
Perhaps recreate a fresh Conda environment and install GDAL in it
Even
> Thanks in advance.
> Regds-
> vijay
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
