[gdal-dev] Java Binding Versions in GDAL Docker Ubuntu Full
Even Rouault even.rouault at spatialys.com
Mon May 1 13:08:16 PDT 2023
Fixed per https://github.com/OSGeo/gdal/pull/7669
Le 01/05/2023 à 19:20, adamgutonski via gdal-dev a écrit :
> Hello,
> I am setting up a Docker container which copies from the GDAL
> ubuntu-full image, and I noticed that the Java bindings with
> ubuntu-full are for Java Version 11 only.  I am using Java Version
> 17.  Are there any deprecated features or potential caveats to be
> aware of when using Java 17 and the GDAL bindings that have been
> compiled for 11?  I can't find any information online about this and I
> do not know how one would rebuild the container bindings.  Perhaps the
> bindings be updated in ubuntu-full in the future?
> Thank you for any information you can provide.
> Kind regards,
> Adam Gutonski
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230501/9422ee38/attachment.htm>
