[gdal-dev] Fwd: Transformation of image data between pixel/line and projected coordinates - using geolocation arrays, in both directions, without disk access
Daniel Scheffler daniel.scheffler at gfz-potsdam.de
Tue May 16 10:35:40 PDT 2023
Hi!
Some time ago, I asked for an inversion of gdal.Warp based on
GEOLOCATION arrays (longitude/latitude). Back then, my question was: How
can I transform an image with projected coordinates back to
cartesian/image coordinates, given that a geolocation array tells GDAL
where to put which pixel in the output?
In 11/2021, this was unfortunately not implemented yet. However, is
seems like in the meantime someting like this has been added:
     - https://github.com/OSGeo/gdal/pull/5520
     - https://github.com/OSGeo/gdal/pull/6069
https://github.com/OSGeo/gdal/blob/c92b22d02c99eae0152f49595947fb3747ddc280/autotest/gcore/geoloc.py#L396
But I am not quite sure if that is what I want. If so, how would a
Python implementation based on gdal.Warp look like? Is that documented
somewhere?
Best,
Daniel
Am 30.11.2021 um 14:20 schrieb Daniel Scheffler:
> Ok thanks, too bad that this is not implemented. I think the inversion
> of this transformation would be a nice feature to be added in GDAL. It
> would be very useful to me (especially if it is accessible via the
> Python bindings) and would ease the implementation in a processing
> pipeline for the upcoming EnMAP hyperspectral satellite. Should I open
> a feature request in the GDAL issue tracker on GitHub?
> Am 30.11.2021 um 14:02 schrieb Even Rouault:
>> Le 30/11/2021 à 12:52, Daniel Scheffler a écrit :
>>> Thanks a lot for taking the time, Even, I got the transformation
>>> from cartesian to projected coordinates to work in memory with the
>>> GTiff driver. With MEM, NUMPY or VRT it does not work because these
>>> formats are either not readable from /vsimem/ or don´t have a
>>> regular file path which is needed to set the X_DATASET and Y_DATASET
>>> keys in the GEOLOCATION metadata.
>> Ah indeed for X_DATASET/Y_DATASET, you can't use a MEM or NUMPY
>> dataset. But a /vsimem/xxx dataset in another format should work.
>>> Regarding the inversion of this transformation, i.e., from projected
>>> coordinates to pixel/line:
>>>> The logic of GDALCreateGenImgProjTransformer2() around
>>>> https://github.com/OSGeo/gdal/blob/master/alg/gdaltransformer.cpp#L1825
>>>> which is for the source dataset should be ported a few lines after
>>>> for the target dataset.  Probably with a new transformer option to
>>>> be able to point to an auxiliary dataset, such as a VRT one of your
>>>> example, to extract the geolocation metadata items from it, that
>>>> would be different from the target dataset itself, because, except
>>>> perhaps for the netCDF case, most GDAL datasets that expose a
>>>> GEOLOCATION metadata domain must be read-only.
>>> I don´t completely get what you mean here. To me, this sounds like
>>> there might be a way to do the inverted transformation using the
>>> C-API of GDAL.
>> No, I meant there's some missing code to do that.
>>> However, I am a Python developer and my C skills are a bit poor. Is
>>> there any way to use the Python bindings here?
>>> Kind regards,
>>> Daniel
>>> Am 26.11.2021 um 12:38 schrieb Even Rouault:
>>>> Daniel,
>>>>> I am trying to convert image data from cartesian/image coordinates
>>>>> to projected coordinates AND vice versa using geolocation arrays
>>>>> in GDAL. I have two questions:
>>>>>  1. Since this transformation is part of a processing chain
>>>>>     implemented in Python, I try to transform the data directly
>>>>>     in-memory, i.e, without any disk access. This saves IO time
>>>>>     and avoids permission errors when trying to write temporary
>>>>>     data on Windows. How can this be done? I got correct results
>>>>>     with the code below, however, only when I temporarily write
>>>>>     the data to disk. I tried to write the data to /vsimem/ using
>>>>>     the MEM, GTiff and NUMPY drivers. However, gdal.Warp can´t
>>>>>     find the data there (FileNotFoundError). I think, also the
>>>>>     gdal.Transformer class might be useful and I found an
>>>>>     interesting thread on that here
>>>>>     <https://lists.osgeo.org/pipermail/gdal-dev/2012-January/031502.html>
>>>>>     and a related test in the GDAL autotest suite (here
>>>>>     <https://github.com/OSGeo/gdal/blob/master/autotest/alg/transformgeoloc.py>).
>>>>>     However, I can´t get it to work for my specific case.
>>>> There's no reason it won't work with a in-memory dataset.
>>>> If you use a MEM dataset, then you need to provide the dataset
>>>> object itself as the input dataset of gdal.Warp() (the name of a
>>>> MEM dataset is completely ignored. a MEM dataset can't be opened,
>>>> just created).
>>>> Similarly with a NUMPY dataset.   With GTiff and /vsimem/, they
>>>> behave as a regular file. If you pass it by name as input of
>>>> gdal.Warp(), you need to make sure to close (ds = None typically)
>>>> the dataset before, so it is properly flushed and can be opened.
>>>> But you can also pass it as an object without that constraint.
>>>> You can also create purely in-memory VRT files by assigning them an
>>>> empty name. Then of course you need to provide them as objects to
>>>> gdal.Warp()
>>>>>  1. My second question is how I can invert the transformation,
>>>>>     i.e., how can I transform an image with projected coordinates
>>>>>     back to cartesian/image coordinates, given that a geolocation
>>>>>     array tells GDAL where to put which pixel in the output?
>>>>>     Background is a processing pipeline for satellite data where
>>>>>     some processing steps are running in sensor geometry (image
>>>>>     data as acquired by the sensor, without any geocoding and
>>>>>     projection) and I need to provide corresponding AUX data which
>>>>>     originally come with projected coordinates.
>>>>> 1.
>>>>> Here is the code I already have to convert a sample image from
>>>>> cartesian to projected coordinates:
>>>>>     import os
>>>>>     from tempfile import TemporaryDirectory
>>>>>     from osgeo import gdal, osr
>>>>>     import numpy as np
>>>>>     from matplotlib import pyplot as plt
>>>>>     # get some test data
>>>>>     swath_data = np.random.randint(1, 100, (500, 400))
>>>>>     lons, lats = np.meshgrid(np.linspace(3, 5, 500),
>>>>>                              np.linspace(40, 42, 400))
>>>>>     with TemporaryDirectory() as td:
>>>>>         p_lons_tmp = os.path.join(td, 'lons.tif')
>>>>>         p_lats_tmp = os.path.join(td, 'lats.tif')
>>>>>         p_data_tmp = os.path.join(td, 'data.tif')
>>>>>         p_data_vrt = os.path.join(td, 'data.vrt')
>>>>>         p_data_mapgeo_vrt = os.path.join(td, 'data_mapgeo.vrt')
>>>>>         # save numpy arrays to temporary tif files
>>>>>         for arr, path in zip((swath_data, lons, lats),
>>>>>     (p_data_tmp, p_lons_tmp, p_lats_tmp)):
>>>>>             rows, cols = arr.shape
>>>>>             drv = gdal.GetDriverByName('GTiff')
>>>>>             ds = drv.Create(path, cols, rows, 1, gdal.GDT_Float64)
>>>>>             ds.GetRasterBand(1).WriteArray(arr)
>>>>>             del ds
>>>>>         # add geolocation information to input data
>>>>>         wgs84_wkt = osr.GetUserInputAsWKT('WGS84')
>>>>>         utm_wkt = osr.GetUserInputAsWKT('EPSG:32632')
>>>>>         ds = gdal.Translate(p_data_vrt, p_data_tmp, format='VRT')
>>>>>         ds.SetMetadata(
>>>>>             dict(
>>>>>                 SRS=wgs84_wkt,
>>>>>                 X_DATASET=p_lons_tmp,
>>>>>                 Y_DATASET=p_lats_tmp,
>>>>>                 X_BAND='1',
>>>>>                 Y_BAND='1',
>>>>>                 PIXEL_OFFSET='0',
>>>>>                 LINE_OFFSET='0',
>>>>>                 PIXEL_STEP='1',
>>>>>                 LINE_STEP='1'
>>>>>             'GEOLOCATION'
>>>>>         )del ds
>>>>>         # warp from geolocation arrays and read the result
>>>>>         gdal.Warp(p_data_mapgeo_vrt, p_data_vrt, format='VRT',
>>>>>     geoloc=True,
>>>>>                   srcSRS=wgs84_wkt, dstSRS=utm_wkt)
>>>>>         data_mapgeo = gdal.Open(p_data_mapgeo_vrt).ReadAsArray()
>>>>>     # visualize input and output data
>>>>>     fig, axes = plt.subplots(1, 4)
>>>>>     for i, (arr, title) in enumerate(zip((swath_data, lons, lats,
>>>>>     data_mapgeo),
>>>>>                                       ('swath data', 'lons',
>>>>>     'lats', 'projected data'))):
>>>>>         axes[i].imshow(arr, cmap='gray')
>>>>>         axes[i].set_title(title)
>>>>>     plt.tight_layout()
>>>>>     plt.show()
>>>>> Any help would be highly appreciated!
>>>>> Best,
>>>>> Daniel Scheffler
>>>>> M.Sc. Geogr. Daniel Scheffler
>>>>> Helmholtz Centre Potsdam
>>>>> GFZ German Research Centre For Geosciences
>>>>> Department 1 - Geodesy and Remote Sensing
>>>>> Section 1.4  - Remote Sensing
>>>>> Telegrafenberg, 14473 Potsdam, Germany
>>>>> Phone:  +49 (0)331/288-1198
>>>>> e-mail:daniel.scheffler at gfz-potsdam.de
>>>>> _______________________________________________
>>>>> gdal-dev mailing list
>>>>> gdal-dev at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>> http://www.spatialys.com
>>>> My software is free, but my time generally not.
Dr. Daniel Scheffler
Section 1.4  - Remote Sensing and Geoinformatics
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230516/8b5724e7/attachment-0001.htm>
