[gdal-dev] Fwd: Transformation of image data between pixel/line and projected coordinates - using geolocation arrays, in both directions, without disk access
Even Rouault even.rouault at spatialys.com
Tue May 16 12:34:49 PDT 2023
Daniel,
You rightly spotted https://github.com/OSGeo/gdal/pull/6069 as the
enabler for that capability.
if your existing target dataset has a geolocation array attached to do
it, this should just be a matter of doing:
target_ds = gdal.Open( filename, gdal.GA_Update )
gdal.Warp(target_ds, source_ds, ... other options here ...)
If the target dataset doesn't have a geolocation array attached to it,
you can point to an external one with the DST_GEOLOC_ARRAY tranformer option
transformerOptions=["DST_METHOD=GEOLOC_ARRAY",
"DST_GEOLOC_ARRAY=/path/to/geoloc_dataset"], ... other options here ...)
Even
Le 16/05/2023 à 19:35, Daniel Scheffler a écrit :
> Hi!
> Some time ago, I asked for an inversion of gdal.Warp based on
> GEOLOCATION arrays (longitude/latitude). Back then, my question was:
> How can I transform an image with projected coordinates back to
> cartesian/image coordinates, given that a geolocation array tells GDAL
> where to put which pixel in the output?
> In 11/2021, this was unfortunately not implemented yet. However, is
> seems like in the meantime someting like this has been added:
>     - https://github.com/OSGeo/gdal/pull/5520
>     - https://github.com/OSGeo/gdal/pull/6069
> https://github.com/OSGeo/gdal/blob/c92b22d02c99eae0152f49595947fb3747ddc280/autotest/gcore/geoloc.py#L396
> But I am not quite sure if that is what I want. If so, how would a
> Python implementation based on gdal.Warp look like? Is that documented
> somewhere?
> Best,
> Daniel
> Am 30.11.2021 um 14:20 schrieb Daniel Scheffler:
>> Ok thanks, too bad that this is not implemented. I think the
>> inversion of this transformation would be a nice feature to be added
>> in GDAL. It would be very useful to me (especially if it is
>> accessible via the Python bindings) and would ease the implementation
>> in a processing pipeline for the upcoming EnMAP hyperspectral
>> satellite. Should I open a feature request in the GDAL issue tracker
>> on GitHub?
>> Am 30.11.2021 um 14:02 schrieb Even Rouault:
>>> Le 30/11/2021 à 12:52, Daniel Scheffler a écrit :
>>>> Thanks a lot for taking the time, Even, I got the transformation
>>>> from cartesian to projected coordinates to work in memory with the
>>>> GTiff driver. With MEM, NUMPY or VRT it does not work because these
>>>> formats are either not readable from /vsimem/ or don´t have a
>>>> regular file path which is needed to set the X_DATASET and
>>>> Y_DATASET keys in the GEOLOCATION metadata.
>>> Ah indeed for X_DATASET/Y_DATASET, you can't use a MEM or NUMPY
>>> dataset. But a /vsimem/xxx dataset in another format should work.
>>>> Regarding the inversion of this transformation, i.e., from
>>>> projected coordinates to pixel/line:
>>>>> The logic of GDALCreateGenImgProjTransformer2() around
>>>>> https://github.com/OSGeo/gdal/blob/master/alg/gdaltransformer.cpp#L1825
>>>>> which is for the source dataset should be ported a few lines after
>>>>> for the target dataset.  Probably with a new transformer option to
>>>>> be able to point to an auxiliary dataset, such as a VRT one of
>>>>> your example, to extract the geolocation metadata items from it,
>>>>> that would be different from the target dataset itself, because,
>>>>> except perhaps for the netCDF case, most GDAL datasets that expose
>>>>> a GEOLOCATION metadata domain must be read-only.
>>>> I don´t completely get what you mean here. To me, this sounds like
>>>> there might be a way to do the inverted transformation using the
>>>> C-API of GDAL.
>>> No, I meant there's some missing code to do that.
>>>> However, I am a Python developer and my C skills are a bit poor. Is
>>>> there any way to use the Python bindings here?
>>>> Kind regards,
>>>> Daniel
>>>> Am 26.11.2021 um 12:38 schrieb Even Rouault:
>>>>> Daniel,
>>>>>> I am trying to convert image data from cartesian/image
>>>>>> coordinates to projected coordinates AND vice versa using
>>>>>> geolocation arrays in GDAL. I have two questions:
>>>>>>  1. Since this transformation is part of a processing chain
>>>>>>     implemented in Python, I try to transform the data directly
>>>>>>     in-memory, i.e, without any disk access. This saves IO time
>>>>>>     and avoids permission errors when trying to write temporary
>>>>>>     data on Windows. How can this be done? I got correct results
>>>>>>     with the code below, however, only when I temporarily write
>>>>>>     the data to disk. I tried to write the data to /vsimem/ using
>>>>>>     the MEM, GTiff and NUMPY drivers. However, gdal.Warp can´t
>>>>>>     find the data there (FileNotFoundError). I think, also the
>>>>>>     gdal.Transformer class might be useful and I found an
>>>>>>     interesting thread on that here
>>>>>>     <https://lists.osgeo.org/pipermail/gdal-dev/2012-January/031502.html>
>>>>>>     and a related test in the GDAL autotest suite (here
>>>>>>     <https://github.com/OSGeo/gdal/blob/master/autotest/alg/transformgeoloc.py>).
>>>>>>     However, I can´t get it to work for my specific case.
>>>>> There's no reason it won't work with a in-memory dataset.
>>>>> If you use a MEM dataset, then you need to provide the dataset
>>>>> object itself as the input dataset of gdal.Warp() (the name of a
>>>>> MEM dataset is completely ignored. a MEM dataset can't be opened,
>>>>> just created).
>>>>> Similarly with a NUMPY dataset.   With GTiff and /vsimem/, they
>>>>> behave as a regular file. If you pass it by name as input of
>>>>> gdal.Warp(), you need to make sure to close (ds = None typically)
>>>>> the dataset before, so it is properly flushed and can be opened.
>>>>> But you can also pass it as an object without that constraint.
>>>>> You can also create purely in-memory VRT files by assigning them
>>>>> an empty name. Then of course you need to provide them as objects
>>>>> to gdal.Warp()
>>>>>>  1. My second question is how I can invert the transformation,
>>>>>>     i.e., how can I transform an image with projected coordinates
>>>>>>     back to cartesian/image coordinates, given that a geolocation
>>>>>>     array tells GDAL where to put which pixel in the output?
>>>>>>     Background is a processing pipeline for satellite data where
>>>>>>     some processing steps are running in sensor geometry (image
>>>>>>     data as acquired by the sensor, without any geocoding and
>>>>>>     projection) and I need to provide corresponding AUX data
>>>>>>     which originally come with projected coordinates.
>>>>>> 1.
>>>>>> Here is the code I already have to convert a sample image from
>>>>>> cartesian to projected coordinates:
>>>>>>     import os
>>>>>>     from tempfile import TemporaryDirectory
>>>>>>     from osgeo import gdal, osr
>>>>>>     import numpy as np
>>>>>>     from matplotlib import pyplot as plt
>>>>>>     # get some test data
>>>>>>     swath_data = np.random.randint(1, 100, (500, 400))
>>>>>>     lons, lats = np.meshgrid(np.linspace(3, 5, 500),
>>>>>>                              np.linspace(40, 42, 400))
>>>>>>     with TemporaryDirectory() as td:
>>>>>>         p_lons_tmp = os.path.join(td, 'lons.tif')
>>>>>>         p_lats_tmp = os.path.join(td, 'lats.tif')
>>>>>>         p_data_tmp = os.path.join(td, 'data.tif')
>>>>>>         p_data_vrt = os.path.join(td, 'data.vrt')
>>>>>>         p_data_mapgeo_vrt = os.path.join(td, 'data_mapgeo.vrt')
>>>>>>         # save numpy arrays to temporary tif files
>>>>>>         for arr, path in zip((swath_data, lons, lats),
>>>>>>     (p_data_tmp, p_lons_tmp, p_lats_tmp)):
>>>>>>             rows, cols = arr.shape
>>>>>>             drv = gdal.GetDriverByName('GTiff')
>>>>>>             ds = drv.Create(path, cols, rows, 1, gdal.GDT_Float64)
>>>>>>             ds.GetRasterBand(1).WriteArray(arr)
>>>>>>             del ds
>>>>>>         # add geolocation information to input data
>>>>>>         wgs84_wkt = osr.GetUserInputAsWKT('WGS84')
>>>>>>         utm_wkt = osr.GetUserInputAsWKT('EPSG:32632')
>>>>>>         ds = gdal.Translate(p_data_vrt, p_data_tmp, format='VRT')
>>>>>>         ds.SetMetadata(
>>>>>>             dict(
>>>>>>                 SRS=wgs84_wkt,
>>>>>>                 X_DATASET=p_lons_tmp,
>>>>>>                 Y_DATASET=p_lats_tmp,
>>>>>>                 X_BAND='1',
>>>>>>                 Y_BAND='1',
>>>>>>                 PIXEL_OFFSET='0',
>>>>>>                 LINE_OFFSET='0',
>>>>>>                 PIXEL_STEP='1',
>>>>>>                 LINE_STEP='1'
>>>>>>             'GEOLOCATION'
>>>>>>         )del ds
>>>>>>         # warp from geolocation arrays and read the result
>>>>>>         gdal.Warp(p_data_mapgeo_vrt, p_data_vrt, format='VRT',
>>>>>>     geoloc=True,
>>>>>>                   srcSRS=wgs84_wkt, dstSRS=utm_wkt)
>>>>>>         data_mapgeo = gdal.Open(p_data_mapgeo_vrt).ReadAsArray()
>>>>>>     # visualize input and output data
>>>>>>     fig, axes = plt.subplots(1, 4)
>>>>>>     for i, (arr, title) in enumerate(zip((swath_data, lons, lats,
>>>>>>     data_mapgeo),
>>>>>>                                       ('swath data', 'lons',
>>>>>>     'lats', 'projected data'))):
>>>>>>         axes[i].imshow(arr, cmap='gray')
>>>>>>         axes[i].set_title(title)
>>>>>>     plt.tight_layout()
>>>>>>     plt.show()
>>>>>> Any help would be highly appreciated!
>>>>>> Best,
>>>>>> Daniel Scheffler
>>>>>> M.Sc. Geogr. Daniel Scheffler
>>>>>> Helmholtz Centre Potsdam
>>>>>> GFZ German Research Centre For Geosciences
>>>>>> Department 1 - Geodesy and Remote Sensing
>>>>>> Section 1.4  - Remote Sensing
>>>>>> Telegrafenberg, 14473 Potsdam, Germany
>>>>>> Phone:  +49 (0)331/288-1198
>>>>>> e-mail:daniel.scheffler at gfz-potsdam.de
>>>>>> _______________________________________________
>>>>>> gdal-dev mailing list
>>>>>> gdal-dev at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>> http://www.spatialys.com
>>>>> My software is free, but my time generally not.
> Dr. Daniel Scheffler
> Section 1.4  - Remote Sensing and Geoinformatics
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230516/1ef9e064/attachment-0001.htm>
