[gdal-dev] Fwd: Transformation of image data between pixel/line and projected coordinates - using geolocation arrays, in both directions, without disk access
Daniel Scheffler daniel.scheffler at gfz-potsdam.de
Wed May 17 06:14:30 PDT 2023
Thanks, Even, that works perfectly! Very nice to have a
GDAL-implementation for that!
Best,
Daniel
Am 16.05.2023 um 21:34 schrieb Even Rouault:
> Daniel,
> You rightly spotted https://github.com/OSGeo/gdal/pull/6069 as the
> enabler for that capability.
> if your existing target dataset has a geolocation array attached to do
> it, this should just be a matter of doing:
> target_ds = gdal.Open( filename, gdal.GA_Update )
> gdal.Warp(target_ds, source_ds, ... other options here ...)
> If the target dataset doesn't have a geolocation array attached to it,
> you can point to an external one with the DST_GEOLOC_ARRAY tranformer
> option
> transformerOptions=["DST_METHOD=GEOLOC_ARRAY",
> "DST_GEOLOC_ARRAY=/path/to/geoloc_dataset"], ... other options here ...)
> Even
> Le 16/05/2023 à 19:35, Daniel Scheffler a écrit :
>> Hi!
>> Some time ago, I asked for an inversion of gdal.Warp based on
>> GEOLOCATION arrays (longitude/latitude). Back then, my question was:
>> How can I transform an image with projected coordinates back to
>> cartesian/image coordinates, given that a geolocation array tells
>> GDAL where to put which pixel in the output?
>> In 11/2021, this was unfortunately not implemented yet. However, is
>> seems like in the meantime someting like this has been added:
>>     - https://github.com/OSGeo/gdal/pull/5520
>>     - https://github.com/OSGeo/gdal/pull/6069
>> https://github.com/OSGeo/gdal/blob/c92b22d02c99eae0152f49595947fb3747ddc280/autotest/gcore/geoloc.py#L396
>> But I am not quite sure if that is what I want. If so, how would a
>> Python implementation based on gdal.Warp look like? Is that
>> documented somewhere?
>> Best,
>> Daniel
>> Am 30.11.2021 um 14:20 schrieb Daniel Scheffler:
>>> Ok thanks, too bad that this is not implemented. I think the
>>> inversion of this transformation would be a nice feature to be added
>>> in GDAL. It would be very useful to me (especially if it is
>>> accessible via the Python bindings) and would ease the
>>> implementation in a processing pipeline for the upcoming EnMAP
>>> hyperspectral satellite. Should I open a feature request in the GDAL
>>> issue tracker on GitHub?
>>> Am 30.11.2021 um 14:02 schrieb Even Rouault:
>>>> Le 30/11/2021 à 12:52, Daniel Scheffler a écrit :
>>>>> Thanks a lot for taking the time, Even, I got the transformation
>>>>> from cartesian to projected coordinates to work in memory with the
>>>>> GTiff driver. With MEM, NUMPY or VRT it does not work because
>>>>> these formats are either not readable from /vsimem/ or don´t have
>>>>> a regular file path which is needed to set the X_DATASET and
>>>>> Y_DATASET keys in the GEOLOCATION metadata.
>>>> Ah indeed for X_DATASET/Y_DATASET, you can't use a MEM or NUMPY
>>>> dataset. But a /vsimem/xxx dataset in another format should work.
>>>>> Regarding the inversion of this transformation, i.e., from
>>>>> projected coordinates to pixel/line:
>>>>>> The logic of GDALCreateGenImgProjTransformer2() around
>>>>>> https://github.com/OSGeo/gdal/blob/master/alg/gdaltransformer.cpp#L1825
>>>>>> which is for the source dataset should be ported a few lines
>>>>>> after for the target dataset.  Probably with a new transformer
>>>>>> option to be able to point to an auxiliary dataset, such as a VRT
>>>>>> one of your example, to extract the geolocation metadata items
>>>>>> from it, that would be different from the target dataset itself,
>>>>>> because, except perhaps for the netCDF case, most GDAL datasets
>>>>>> that expose a GEOLOCATION metadata domain must be read-only.
>>>>> I don´t completely get what you mean here. To me, this sounds like
>>>>> there might be a way to do the inverted transformation using the
>>>>> C-API of GDAL.
>>>> No, I meant there's some missing code to do that.
>>>>> However, I am a Python developer and my C skills are a bit poor.
>>>>> Is there any way to use the Python bindings here?
>>>>> Kind regards,
>>>>> Daniel
>>>>> Am 26.11.2021 um 12:38 schrieb Even Rouault:
>>>>>> Daniel,
>>>>>>> I am trying to convert image data from cartesian/image
>>>>>>> coordinates to projected coordinates AND vice versa using
>>>>>>> geolocation arrays in GDAL. I have two questions:
>>>>>>>  1. Since this transformation is part of a processing chain
>>>>>>>     implemented in Python, I try to transform the data directly
>>>>>>>     in-memory, i.e, without any disk access. This saves IO time
>>>>>>>     and avoids permission errors when trying to write temporary
>>>>>>>     data on Windows. How can this be done? I got correct results
>>>>>>>     with the code below, however, only when I temporarily write
>>>>>>>     the data to disk. I tried to write the data to /vsimem/
>>>>>>>     using the MEM, GTiff and NUMPY drivers. However, gdal.Warp
>>>>>>>     can´t find the data there (FileNotFoundError). I think, also
>>>>>>>     the gdal.Transformer class might be useful and I found an
>>>>>>>     interesting thread on that here
>>>>>>>     <https://lists.osgeo.org/pipermail/gdal-dev/2012-January/031502.html>
>>>>>>>     and a related test in the GDAL autotest suite (here
>>>>>>>     <https://github.com/OSGeo/gdal/blob/master/autotest/alg/transformgeoloc.py>).
>>>>>>>     However, I can´t get it to work for my specific case.
>>>>>> There's no reason it won't work with a in-memory dataset.
>>>>>> If you use a MEM dataset, then you need to provide the dataset
>>>>>> object itself as the input dataset of gdal.Warp() (the name of a
>>>>>> MEM dataset is completely ignored. a MEM dataset can't be opened,
>>>>>> just created).
>>>>>> Similarly with a NUMPY dataset.   With GTiff and /vsimem/, they
>>>>>> behave as a regular file. If you pass it by name as input of
>>>>>> gdal.Warp(), you need to make sure to close (ds = None typically)
>>>>>> the dataset before, so it is properly flushed and can be opened.
>>>>>> But you can also pass it as an object without that constraint.
>>>>>> You can also create purely in-memory VRT files by assigning them
>>>>>> an empty name. Then of course you need to provide them as objects
>>>>>> to gdal.Warp()
>>>>>>>  1. My second question is how I can invert the transformation,
>>>>>>>     i.e., how can I transform an image with projected
>>>>>>>     coordinates back to cartesian/image coordinates, given that
>>>>>>>     a geolocation array tells GDAL where to put which pixel in
>>>>>>>     the output? Background is a processing pipeline for
>>>>>>>     satellite data where some processing steps are running in
>>>>>>>     sensor geometry (image data as acquired by the sensor,
>>>>>>>     without any geocoding and projection) and I need to provide
>>>>>>>     corresponding AUX data which originally come with projected
>>>>>>>     coordinates.
>>>>>>> 1.
>>>>>>> Here is the code I already have to convert a sample image from
>>>>>>> cartesian to projected coordinates:
>>>>>>>     import os
>>>>>>>     from tempfile import TemporaryDirectory
>>>>>>>     from osgeo import gdal, osr
>>>>>>>     import numpy as np
>>>>>>>     from matplotlib import pyplot as plt
>>>>>>>     # get some test data
>>>>>>>     swath_data = np.random.randint(1, 100, (500, 400))
>>>>>>>     lons, lats = np.meshgrid(np.linspace(3, 5, 500),
>>>>>>>                              np.linspace(40, 42, 400))
>>>>>>>     with TemporaryDirectory() as td:
>>>>>>>         p_lons_tmp = os.path.join(td, 'lons.tif')
>>>>>>>         p_lats_tmp = os.path.join(td, 'lats.tif')
>>>>>>>         p_data_tmp = os.path.join(td, 'data.tif')
>>>>>>>         p_data_vrt = os.path.join(td, 'data.vrt')
>>>>>>>         p_data_mapgeo_vrt = os.path.join(td, 'data_mapgeo.vrt')
>>>>>>>         # save numpy arrays to temporary tif files
>>>>>>>         for arr, path in zip((swath_data, lons, lats),
>>>>>>>     (p_data_tmp, p_lons_tmp, p_lats_tmp)):
>>>>>>>             rows, cols = arr.shape
>>>>>>>             drv = gdal.GetDriverByName('GTiff')
>>>>>>>             ds = drv.Create(path, cols, rows, 1, gdal.GDT_Float64)
>>>>>>>             ds.GetRasterBand(1).WriteArray(arr)
>>>>>>>             del ds
>>>>>>>         # add geolocation information to input data
>>>>>>>         wgs84_wkt = osr.GetUserInputAsWKT('WGS84')
>>>>>>>         utm_wkt = osr.GetUserInputAsWKT('EPSG:32632')
>>>>>>>         ds = gdal.Translate(p_data_vrt, p_data_tmp, format='VRT')
>>>>>>>         ds.SetMetadata(
>>>>>>>             dict(
>>>>>>>                 SRS=wgs84_wkt,
>>>>>>>                 X_DATASET=p_lons_tmp,
>>>>>>>                 Y_DATASET=p_lats_tmp,
>>>>>>>                 X_BAND='1',
>>>>>>>                 Y_BAND='1',
>>>>>>>                 PIXEL_OFFSET='0',
>>>>>>>                 LINE_OFFSET='0',
>>>>>>>                 PIXEL_STEP='1',
>>>>>>>                 LINE_STEP='1'
>>>>>>>             'GEOLOCATION'
>>>>>>>         )del ds
>>>>>>>         # warp from geolocation arrays and read the result
>>>>>>>         gdal.Warp(p_data_mapgeo_vrt, p_data_vrt, format='VRT',
>>>>>>>     geoloc=True,
>>>>>>>                   srcSRS=wgs84_wkt, dstSRS=utm_wkt)
>>>>>>>         data_mapgeo = gdal.Open(p_data_mapgeo_vrt).ReadAsArray()
>>>>>>>     # visualize input and output data
>>>>>>>     fig, axes = plt.subplots(1, 4)
>>>>>>>     for i, (arr, title) in enumerate(zip((swath_data, lons,
>>>>>>>     lats, data_mapgeo),
>>>>>>>                                       ('swath data', 'lons',
>>>>>>>     'lats', 'projected data'))):
>>>>>>>         axes[i].imshow(arr, cmap='gray')
>>>>>>>         axes[i].set_title(title)
>>>>>>>     plt.tight_layout()
>>>>>>>     plt.show()
>>>>>>> Any help would be highly appreciated!
>>>>>>> Best,
>>>>>>> Daniel Scheffler
>>>>>>> M.Sc. Geogr. Daniel Scheffler
>>>>>>> Helmholtz Centre Potsdam
>>>>>>> GFZ German Research Centre For Geosciences
>>>>>>> Department 1 - Geodesy and Remote Sensing
>>>>>>> Section 1.4  - Remote Sensing
>>>>>>> Telegrafenberg, 14473 Potsdam, Germany
>>>>>>> Phone:  +49 (0)331/288-1198
>>>>>>> e-mail:daniel.scheffler at gfz-potsdam.de
>>>>>>> _______________________________________________
>>>>>>> gdal-dev mailing list
>>>>>>> gdal-dev at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>>> http://www.spatialys.com
>>>>>> My software is free, but my time generally not.
>> Dr. Daniel Scheffler
>> Section 1.4  - Remote Sensing and Geoinformatics
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230517/aa3b0dfe/attachment-0001.htm>
