[gdal-dev] Improving details of the project build system and/or documentation
Sean Gillies sean.gillies at gmail.com
Fri May 19 16:26:26 PDT 2023
Hi all,
I really appreciate the documentation at
https://gdal.org/development/building_from_source.html. But there are gaps.
For example, today I ran into
CMake Error at cmake/helpers/GdalDriverHelper.cmake:331 (message):
GDAL_ENABLE_DRIVER_AIGRID cannot be enabled because condition
OGR_ENABLE_DRIVER_AVC is not met. To ignore this error (but the driver
will not be built), set the GDAL_IGNORE_FAILED_CONDITIONS variable
This dependence isn't documented. It's a bit frustrating to work through
missing directives one at a time when adding new drivers to my build.
Is it possible for a driver's dependencies to be enabled when I enable a
driver?
If not, can we consider using GDAL maintenance funding and resources on
documenting the heck out of this system?
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230519/97c87b53/attachment.htm>
