[gdal-dev] GDAL 3.8.0beta1 available for testing
Even Rouault even.rouault at spatialys.com
Wed Nov 1 05:17:33 PDT 2023
Hi Mike,
thanks for the report. Issue fixed in master. I've refreshed the Docker
Note however that this Overture dataset contains 1,390,499,721 features,
and with our estimate of 83 bytes / feature to build the FlatGeobuf
RTree, that means you need at least 115 GB RAM on your machine
(presumably more due to fragmentation etc)
You could potentially save a few minutes by not adding -progress since
GetFeatureCount() on such dataset requires getting some bits in each of
the ~1600 files, but I guess that for a process that's going to take a
few hours, having some display progress justifies a few extra minutes :-)
Even
Le 01/11/2023 à 11:18, Michael Smith a écrit :
> Using the ghcr.io/osgeo/gdal:ubuntu-full-latest docker image, I get a
> segfault when trying to convert overture maps to flatgeobuf
> ogr2ogr -f flatgeobuf /data/overturemaps_2023_10_19.fgb
> /vsis3/overturemaps-us-west-2/release/2023-10-19-alpha.0/theme=buildings/
> theme=buildings -progress
> FlatGeobuf: Spatial index requested will write to temp file and do
> second pass on close
> Segmentation fault (core dumped)
> But no core file.
> Michael Smith
> Remote Sensing/GIS Center
> US Army Corps of Engineers
> *From: *gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Even
> Rouault via gdal-dev <gdal-dev at lists.osgeo.org>
> *Reply-To: *Even Rouault <even.rouault at spatialys.com>
> *Date: *Tuesday, October 31, 2023 at 1:14 PM
> *To: *Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>,
> "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
> *Subject: *Re: [gdal-dev] GDAL 3.8.0beta1 available for testing
> Le 31/10/2023 à 17:36, Rahkonen Jukka a écrit :
>     Hi,
>     I made a simple test with ogr2ogr and geopackage to geopackage on Windows. With GDAL 3.8.0dev-3e4dc710a2 (no arrow, old R-Tree) the timing was 36 minutes, with GDAL 3.8.0dev-6bbd2c080a the same conversion took 21 minutes. The gpkg file is 75 GB, with 120 layers.
>     Could it be that the new R-Tree implementation does not print anything into debug?
> Indeed. Debug traces added back in https://github.com/OSGeo/gdal/pull/8640
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> _______________________________________________ gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231101/89063869/attachment-0001.htm>
