[gdal-dev] Call for review and discussion on RFC96: Deferred in-tree C++ plugin loading
Even Rouault even.rouault at spatialys.com
Thu Nov 2 14:20:06 PDT 2023
Howard,
> I would like to see some language that describes the expectations for
> version compatibility of plugins (ie, what happens with a plugin built
> against x.0 is used against a main library of y.0).
This RFC actually doesn't change anything regarding this. See the
mention of the GDAL_CHECK_VERSION macro in
https://gdal.org/tutorials/raster_driver_tut.html#the-driver which
covers this topic (I've just slightly tuned it to the below version
which will be online soon):
"Note the use of GDAL_CHECK_VERSION macro. This is a macro that should
be used by drivers that can be built as a plugin. As the GDAL C++ ABI
may, and will, change between GDAL feature releases (for example from
GDAL 3.x.0 to 3.y.0), it is necessary to recompile your driver against
the header files of the GDAL feature version with which you want to make
it work. The GDAL_CHECK_VERSION macro will check that the GDAL version
with which the driver was compiled and the version against which it is
running are compatible (checking that the major and minor version
numbers are equal). The C++ ABI will however remain stable for releases
of the same release branch (that is for bug fixes releases x.y.z of a
given feature release x.y.0)."
Even
http://www.spatialys.com
