[gdal-dev] Call for review and discussion on RFC96: Deferred in-tree C++ plugin loading
Even Rouault even.rouault at spatialys.com
Mon Nov 6 05:50:25 PST 2023
I've revised a bit the RFC
(https://github.com/OSGeo/gdal/pull/8648/commits/b7053db2f433275edf16286596e71f3ceb9738a5)
to unify the way the plugin driver proxy and the actual driver declare
their metadata. This avoids the new GDALPluginDriverFeatures class, and
will limit the risk of omissions or inconsistencies between the proxy
and actual drivers.
Even
Le 02/11/2023 à 12:59, Even Rouault via gdal-dev a écrit :
> Hi,
> I'm seeking for feedback and review on a new RFC (RFC 96: Deferred
> in-tree C++ plugin loading),
> detailed in https://github.com/OSGeo/gdal/pull/8648, whose summary is:
> This RFC adds a mechanism to defer the loading of in-tree C++ plugin
> drivers to
> the point where their executable code is actually needed, and converts
> a number
> of relevant drivers to use that mechanism. The aim is to allow for
> more modular
> GDAL builds, while improving the performance of plugin loading.
> (This is material only for GDAL 3.9 of course)
> Even
http://www.spatialys.com
