[gdal-dev] Show isBigTIFF in image metadata
Kurt Schwehr schwehr at gmail.com
Thu Nov 2 18:07:54 PDT 2023
Jukka,
What's the exact use case for needing to know if a tiff is traditional or
BigTIFF? Is there a key tool that doesn't understand BigTIFF? The only one
I know of is Autodesk Civil3D.
Thanks,
-Kurt
On Thu, Nov 2, 2023 at 2:49 PM Even Rouault via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Jukka,
> Does it feel reasonable? I know that overviews may be standard TIFFs while
> the main image is BigTIFF but maybe the information from the header would
> be enough. Or have I missed some existing tool? I thought that tiffinfo at
> least would report TIFF/BigTIFF but it doesn’t.
> tiffdump does:
> $ tiffdump byte.tif
> byte.tif:
> Magic: 0x4949 <little-endian> Version: 0x2a <ClassicTIFF>
> vs
> $ tiffdump bigtiff.tif
> bigtiff.tif:
> Magic: 0x4949 <little-endian> Version: 0x2b <BigTIFF>
> Even
> -- http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231102/129c32d0/attachment-0001.htm>
