[gdal-dev] Show isBigTIFF in image metadata
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Fri Nov 3 01:51:48 PDT 2023
The exact use case is for the GDAL community help desk. I was wondering how this user https://gis.stackexchange.com/questions/469512/cannot-write-geotiff-larger-than-4gb-with-gdalwarp-despite-using-bigtiff-createo could check if their TIFF is created as BigTIFF or not.
-Jukka Rahkonen-
Lähettäjä: Kurt Schwehr <schwehr at gmail.com>
Lähetetty: perjantai 3. marraskuuta 2023 3.08
Vastaanottaja: Even Rouault <even.rouault at spatialys.com>
Kopio: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>; 'gdal-dev at lists.osgeo.org' (gdal-dev at lists.osgeo.org) <gdal-dev at lists.osgeo.org>
Aihe: Re: [gdal-dev] Show isBigTIFF in image metadata
Jukka,
What's the exact use case for needing to know if a tiff is traditional or BigTIFF? Is there a key tool that doesn't understand BigTIFF? The only one I know of is Autodesk Civil3D.
Thanks,
-Kurt
On Thu, Nov 2, 2023 at 2:49 PM Even Rouault via gdal-dev <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>> wrote:
Jukka,
Does it feel reasonable? I know that overviews may be standard TIFFs while the main image is BigTIFF but maybe the information from the header would be enough. Or have I missed some existing tool? I thought that tiffinfo at least would report TIFF/BigTIFF but it doesn’t.
tiffdump does:
$ tiffdump byte.tif
byte.tif:
Magic: 0x4949 <little-endian> Version: 0x2a <ClassicTIFF>
vs
$ tiffdump bigtiff.tif
bigtiff.tif:
Magic: 0x4949 <little-endian> Version: 0x2b <BigTIFF>
Even
http://www.spatialys.com<http://www.spatialys.com/>
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231103/9ed25c57/attachment.htm>
