[gdal-dev] oblique cuts on a raster using python GDAL
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Sun Nov 5 10:43:20 PST 2023
Please add gdalinfo of the source image. Even better if you can share the image.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Naima Dambrine via gdal-dev
Lähetetty: sunnuntai 5. marraskuuta 2023 17.35
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] oblique cuts on a raster using python GDAL
Hi ,
I have problems with oblique cuts on a raster using python GDAL (3.6.2)
- with this line i obtain black borders around :
gdal.warp('raster-dst' , raster-src', cutLineDSName='geometry-extraction.shp', cropToCutline=True)
- with this one, the crop is not clean on closer inspection: residual black pixels around image and white pixels appear in the image.
gdal. warp( 'raster-dst' , raster-src', cutLineDSName='geometry-extraction.shp', cropToCutline=True, copyMetaData=True, dstNodata=0)
I tried, without success, to refine with outputBounds=[minX, maxX, minY, maxY], under QGIS directly ….
I've run out of ideas :/
A (naive) question comes to mind: Is it possible to make oblique cuts with gdal.warp() & co?
Naïma
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231105/977e5f56/attachment-0001.htm>
