[gdal-dev] oblique cuts on a raster using python GDAL
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Nov 6 02:33:04 PST 2023
Hi Naima
I have been testing with your dataset. To me, using the GDAL in Ubuntu
22.04 (3.4.1) seems to be a problem with the JP2 output format. If you
output as geotiff it works fine.
On Sun, 5 Nov 2023 at 19:43, Rahkonen Jukka via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> Please add gdalinfo of the source image. Even better if you can share the
> image.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Naima
> Dambrine via gdal-dev
> *Lähetetty:* sunnuntai 5. marraskuuta 2023 17.35
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] oblique cuts on a raster using python GDAL
> Hi ,
> I have problems with oblique cuts on a raster using python GDAL (3.6.2)
> - with this line i obtain black borders around :
> gdal.warp('raster-dst' , raster-src',
> cutLineDSName='geometry-extraction.shp', cropToCutline=True)
> - with this one, the crop is not clean on closer inspection: residual
> black pixels around image and white pixels appear in the image.
> gdal. warp( 'raster-dst' , raster-src',
> cutLineDSName='geometry-extraction.shp', cropToCutline=True,
> copyMetaData=True, dstNodata=0)
> I tried, without success, to refine with outputBounds=[minX, maxX, minY,
> maxY], under QGIS directly ….
> I've run out of ideas :/
> A (naive) question comes to mind: Is it possible to make oblique cuts with
> gdal.warp() & co?
> Naïma
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231106/b11ac818/attachment.htm>
