[gdal-dev] GDAL PDF Export: Support for different page sizes and multi-paged PDF
Mandeep Singh mandeepsinghkalra at gmail.com
Mon Nov 13 04:02:58 PST 2023
I am currently using the GDAL Library for exporting the PDFs. Using the
gdal_translate command to generate the PDF from VRT, I am able to generate
a PDF. I have below queries:
- Is there any option to export a multi page PDF?
- How can I control the page size of each page in the PDF ?
Regards
Mandeep
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231113/1576739e/attachment.htm>
