[gdal-dev] GDAL PDF Export: Support for different page sizes and multi-paged PDF
Laurențiu Nicola lnicola at dend.ro
Tue Nov 14 05:34:52 PST 2023
Hi Mandeep,
I've never used it, but perhaps you should try https://gdal.org/drivers/raster/pdf.html#creation-of-pdf-file-from-a-xml-composition-file-gdal-3-0 in combination with gdal_create?
Laurențiu
On Mon, Nov 13, 2023, at 14:02, Mandeep Singh via gdal-dev wrote:
> Hi,
> I am currently using the GDAL Library for exporting the PDFs. Using the  gdal_translate command to generate the PDF from VRT, I am able to generate a PDF. I have below queries:
> - Is there any option to export a multi page PDF?
> - How can I control the page size of each page in the PDF ?
> Regards
> Mandeep
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231114/b7a4049f/attachment.htm>
