[gdal-dev] GDAL PDF Export: Support for different page sizes and multi-paged PDF
Mandeep Singh mandeepsinghkalra at gmail.com
Tue Nov 14 09:56:43 PST 2023
Thanks, i tried the same but for some reason the vector data was not
displayed in the pdf i guess due to georeferenced control points
1) How do i set the control points based on page size and dpi, eg if i have
to use EPSG 3857 system. Is there any utility i can use to do this
conversion ?
2) In the vector dataset, can i use VRT file instead of shape files ?
Regards
Mandeep
On Tue, 14 Nov 2023 at 7:05 PM, Laurențiu Nicola via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi Mandeep,
> I've never used it, but perhaps you should try
> https://gdal.org/drivers/raster/pdf.html#creation-of-pdf-file-from-a-xml-composition-file-gdal-3-0 in
> combination with gdal_create?
> Laurențiu
> On Mon, Nov 13, 2023, at 14:02, Mandeep Singh via gdal-dev wrote:
> Hi,
> I am currently using the GDAL Library for exporting the PDFs. Using the
> gdal_translate command to generate the PDF from VRT, I am able to generate
> a PDF. I have below queries:
> - Is there any option to export a multi page PDF?
> - How can I control the page size of each page in the PDF ?
> Regards
> Mandeep
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231114/bf219593/attachment.htm>
