[gdal-dev] GDAL PDF Export: Support for different page sizes and multi-paged PDF
Laurențiu Nicola lnicola at dend.ro
Tue Nov 14 10:04:20 PST 2023
On Tue, Nov 14, 2023, at 19:56, Mandeep Singh wrote:
> Thanks, i tried the same but for some reason the vector data was not displayed in the pdf i guess due to georeferenced control points
> 1) How do i set the control points based on page size and dpi, eg if i have to use EPSG 3857 system. Is there any utility i can use to do this conversion ?
I don't know, maybe it's enough to set SRS, BoundingBox and BoundingPolygon to your EPSG:3857 values, without any control points. The example there seems to take a more flexible approach.
> 2) In the vector dataset, can i use VRT file instead of shape files ?
If your VRT has vector data, I don't see why not.
Laurentiu
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231114/ced9350b/attachment.htm>
