[gdal-dev] Is the SOSI Norwegian driver still useful?
Sebastiaan Couwenberg sebastic at xs4all.nl
Tue Nov 14 11:41:26 PST 2023
On 11/14/23 20:05, Even Rouault via gdal-dev wrote:
> Le 14/11/2023 à 19:48, Sebastiaan Couwenberg via gdal-dev a écrit :
>> On 11/14/23 19:16, Even Rouault via gdal-dev wrote:
>>> ==> Are there users still using the existing OGR SOSI driver ?
>> We don't have metrics for the OGR driver, but libfyba0 still has 513
>> users in popcon.
>>  https://qa.debian.org/popcon.php?package=fyba
> Looking in the same column in
> https://qa.debian.org/popcon.php?package=gdal shows that gdal-bin would
> have only 520 users...  which seems highly suspiciously low compared to
> the super specialized and low level libfyba.  I would bet that > 99% of
> installations of libfyba0 are because libgdal links to it, which doesn't
> mean that it is used for useful stuff (the other reverse dependency of
> libfyba in Debian is sosi2osm, which according to
> https://qa.debian.org/popcon.php?package=sosi2osm, has only 3 users)
sosi2osm was removed from Debian during the bookworm development cycle.
The only rdep of fyba in Debian is gdal now.
Almost all installations of libfyba are due to it being a dependency of
gdal, that's why it has 23911 installations but only 513 votes (regular
users).
> What if people build a Docker image of GDAL from source and install its
> dependencies with apt install libfyba-dev: will that trigger a hit in
> popcorn?
popcon is opt-in, there are only ~230000 systems running popcon out of
millions of Debian installations. Hence it's mostly usable to provide
insight into relative popularity compared to other packages in Debian.
Container images are unlikely to enable popcon, the Docker images don't
even have it installed.
> I'm more interested in Norwegian flesh and bones users testifying about
> their use or non-use of SOSI.
Me too, if there are none left we can also remove the fyba package from
Debian.
Kind Regards,
Bas
  GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
