[gdal-dev] Converting parquet to geopackage
Even Rouault even.rouault at spatialys.com
Thu Nov 16 06:08:35 PST 2023
Michael,
this error comes from libarrow-cpp.
Several potential causes:
- one of the parquet file is corrupted
- one of the parquet files is valid but uses "something" that
libarrow-cpp can't understand. I mention this because we have seen an
interoperability issues between files generated by the go implementation
of parquet and libarrow-cpp. Not clear which end is the culprit. But the
error message was different than yours
- there's an I/O error when getting data from S3
- some other bug in libarrow-cpp...
Perhaps run in --debug on mode to see in the traces which parquet file
cause the issue ? (assuming that the error can also be reproduced when
reading one of the component parquet files, and not just when reading
the whole dataset...)
https://github.com/search?q=repo%3Aapache%2Farrow+TProtocolException%3A+Exceeded+size+limit&type=issues
shows a number of issues where this error message pops up
Even
Le 16/11/2023 à 14:37, Smith, Michael ERDC-RDE-CRREL-NH CIV via gdal-dev
a écrit :
> Using gdal3.8 (ghcr.io/osgeo/gdal:ubuntu-full-3.8.0) , got an error I
> haven’t seen before:
> ReadNext() failed: Couldn't deserialize thrift: TProtocolException:
> Exceeded size limit
> Deserializing page header failed.
> This happened at 92%
> Command: ogr2ogr -f gpkg /data/overturemaps_2023_11_14.gpkg
> /vsis3/overturemaps-us-west-2/release/2023-11-14-alpha.0/theme=buildings/
> theme=buildings -progress -NLT MULTIPOLYGON
> So anyone know what this means and what caused it and any workarounds?
> Mike
> Michael Smith
> US Army Corps of Engineers
> Remote Sensing/GIS Center
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231116/85829f8d/attachment.htm>
