[gdal-dev] COPY statement failed with PG_USE_COPY=YES
Even Rouault even.rouault at spatialys.com
Tue Nov 21 03:24:53 PST 2023
Matteo,
 From a quick test, I can't reproduce. Please provide a minimum
shapefile that reproduces the issue
$ cat test.csv
id,dt
1,"0000/00/00"
$ cat test.csvt
Integer,Date
$ ogr2ogr date_null.shp test.csv
Warning 1: Invalid value type found in record 1 for field dt. This
warning will no longer be emitted
$ ogr2ogr pg:dbname=autotest date_null.dbf --config PG_USE_COPY YES
-overwrite
$ ogrinfo pg:dbname=autotest date_null -al
INFO: Open of `pg:dbname=autotest'
       using driver `PostgreSQL' successful.
Layer name: date_null
Geometry: None
Feature Count: 1
Layer SRS WKT:
(unknown)
FID Column = ogc_fid
dt: Date
OGRFeature(date_null):1
   id (Integer) = 1
   dt (Date) = (null)
Even
Le 21/11/2023 à 09:24, Matteo Ghetta via gdal-dev a écrit :
> Hi all,
> I'm trying to import (many) shapefiles into a PG database. I'm facing
> the following error, but only when PG_USE_COPY is set to YES:
> ERROR 1: COPY statement failed.
> ERROR:  date/time field value out of range: "0000/00/00"
> CONTEXT:  COPY TABLE, line 12682, column DATA_INI: "0000/00/00"
> The value in the source shapefile is NULL for some rows. With
> PG_USE_COPY NO the import works perfectly.
> I've found this old ticket, that seems to describe this exact issue,
> and is marked as resolved:
> https://trac.osgeo.org/gdal/ticket/4265
> Tested with:
> * GDAL 3.2.2, released 2021/03/05
> * GDAL 3.7.3, released 2023/10/30
> Do you have any ideas about what is causing this?
> Cheers and thanks
> Matteo
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
