[gdal-dev] COPY statement failed with PG_USE_COPY=YES
Matteo Ghetta matteo.ghetta at gmail.com
Mon Nov 27 07:04:20 PST 2023
Hi Even,
sorry for the delay. In attach you can find a shapefile and here the
command I'm using:
ogr2ogr -progress --config PG_USE_COPY YES --config SHAPE_ENCODING
LATIN1 -f PostgreSQL PG:"host=XX port=XX dbname=XX user=XX password=XX
active_schema=gis" -lco DIM=4 /path/to/FOG_NODI_PT_GIS.shp
FOG_NODI_PT_GIS -lco LAUNDER=NO -overwrite -nlt POINT -lco
GEOMETRY_NAME=geom -lco FID=id -nln gis."FOG_NODI_PT_GIS" -s_srs
EPSG:23032 -t_srs EPSG:4326
Cheers and thanks!
Matteo
On 11/21/23 12:24, Even Rouault wrote:
> Matteo,
>  From a quick test, I can't reproduce. Please provide a minimum
> shapefile that reproduces the issue
> $ cat test.csv
> id,dt
> 1,"0000/00/00"
> $ cat test.csvt
> Integer,Date
> $ ogr2ogr date_null.shp test.csv
> Warning 1: Invalid value type found in record 1 for field dt. This
> warning will no longer be emitted
> $ ogr2ogr pg:dbname=autotest date_null.dbf --config PG_USE_COPY YES
> -overwrite
> $ ogrinfo pg:dbname=autotest date_null -al
> INFO: Open of `pg:dbname=autotest'
>        using driver `PostgreSQL' successful.
> Layer name: date_null
> Geometry: None
> Feature Count: 1
> Layer SRS WKT:
> (unknown)
> FID Column = ogc_fid
> dt: Date
> OGRFeature(date_null):1
>    id (Integer) = 1
>    dt (Date) = (null)
> Even
> Le 21/11/2023 à 09:24, Matteo Ghetta via gdal-dev a écrit :
>> Hi all,
>> I'm trying to import (many) shapefiles into a PG database. I'm facing
>> the following error, but only when PG_USE_COPY is set to YES:
>> ERROR 1: COPY statement failed.
>> ERROR:  date/time field value out of range: "0000/00/00"
>> CONTEXT:  COPY TABLE, line 12682, column DATA_INI: "0000/00/00"
>> The value in the source shapefile is NULL for some rows. With
>> PG_USE_COPY NO the import works perfectly.
>> I've found this old ticket, that seems to describe this exact issue,
>> and is marked as resolved:
>> https://trac.osgeo.org/gdal/ticket/4265
>> Tested with:
>> * GDAL 3.2.2, released 2021/03/05
>> * GDAL 3.7.3, released 2023/10/30
>> Do you have any ideas about what is causing this?
>> Cheers and thanks
>> Matteo
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231127/678576b0/attachment-0001.zip>
