[gdal-dev] Problems compiling in Mac
Even Rouault even.rouault at spatialys.com
Thu Nov 23 07:25:23 PST 2023
>>     I thought that it was enough disabling GDAL_USE_EXTERNAL_LIBS (we
>>     are not enabling explicitly arrow or kml). Am I wrong?
>     He might have to remove CMakeCache.txt because it could contain
>     the GDAL_USE_LIBKML=ON declaration that was set before turning off
> He started from an empty directory.
> We are using conan, that is python, and setting
> GDAL_USE_EXTERNAL_LIBS=False . This is the result after searching for
> that string:
and what is the value of GDAL_USE_LIBKML and GDAL_USE_ARROW ? and what
is the exact error message?
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231123/c2f03288/attachment.htm>
