[gdal-dev] Problems compiling in Mac
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Nov 23 09:12:21 PST 2023
My colleague (I have only Linux) will give more info.
On Thu, 23 Nov 2023 at 16:25, Even Rouault <even.rouault at spatialys.com>
wrote:
>> I thought that it was enough disabling GDAL_USE_EXTERNAL_LIBS (we are not
>> enabling explicitly arrow or kml). Am I wrong?
>> He might have to remove CMakeCache.txt because it could contain the
>> GDAL_USE_LIBKML=ON declaration that was set before turning off
> He started from an empty directory.
> We are using conan, that is python, and setting
> GDAL_USE_EXTERNAL_LIBS=False . This is the result after searching for that
> string:
> and what is the value of GDAL_USE_LIBKML and GDAL_USE_ARROW ? and what is
> the exact error message?
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231123/51a7ace1/attachment-0001.htm>
