[gdal-dev] GDAL 3.8.1 RC2 is available (was Re: GDAL 3.8.1 RC1 is available, and motion to approve it)
Even Rouault even.rouault at spatialys.com
Fri Nov 24 03:05:45 PST 2023
OK, I've reverted that change. I'll guess someone will have to figure
out how to have both .py scripts and .exe/.sh launchers at the same time...
Pick up an archive among the following ones (by ascending size):
   https://download.osgeo.org/gdal/3.8.1/gdal-3.8.1rc2.tar.xz
   https://download.osgeo.org/gdal/3.8.1/gdal-3.8.1rc2.tar.gz
   https://download.osgeo.org/gdal/3.8.1/gdal381rc2.zip
A snapshot of the gdalautotest suite is also available:
https://download.osgeo.org/gdal/3.8.1/gdalautotest-3.8.1rc2.tar.gz
   https://download.osgeo.org/gdal/3.8.1/gdalautotest-3.8.1rc2.zip
Withdrawing previous motion and:
Motion: adopt 3.8.1 RC2 as final 3.8.1 release
Starting with my +1,
Even
Le 24/11/2023 à 06:34, Sebastiaan Couwenberg via gdal-dev a écrit :
> On 11/23/23 22:56, Even Rouault via gdal-dev wrote:
>>  From a packaging point of view, the following change might have
>> impacts on
>> build recipes:
> The Python utilities are no longer installed with the .py extension,
> this broke their use in QGIS when we removed this in the Debian
> package some time ago. Don't know if that's still the case. Either
> way, this doesn't seem like an appropriate change for a .1 patch release.
> usr/bin/__init__ is now also installed which not correct.
> Kind Regards,
> Bas
http://www.spatialys.com
