[gdal-dev] GDAL 3.8.1 RC2 is available (was Re: GDAL 3.8.1 RC1 is available, and motion to approve it)
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Mon Nov 27 08:30:27 PST 2023
+1
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Even Rouault via gdal-dev
Lähetetty: perjantai 24. marraskuuta 2023 13.06
Vastaanottaja: Sebastiaan Couwenberg <sebastic at xs4all.nl>; gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] GDAL 3.8.1 RC2 is available (was Re: GDAL 3.8.1 RC1 is available, and motion to approve it)
OK, I've reverted that change. I'll guess someone will have to figure out how to have both .py scripts and .exe/.sh launchers at the same time...
Pick up an archive among the following ones (by ascending size):
Withdrawing previous motion and:
Motion: adopt 3.8.1 RC2 as final 3.8.1 release
Starting with my +1,
Even
Le 24/11/2023 à 06:34, Sebastiaan Couwenberg via gdal-dev a écrit :
> On 11/23/23 22:56, Even Rouault via gdal-dev wrote:
>>  From a packaging point of view, the following change might have
>> impacts on build recipes:
> The Python utilities are no longer installed with the .py extension,
> this broke their use in QGIS when we removed this in the Debian
> package some time ago. Don't know if that's still the case. Either
> way, this doesn't seem like an appropriate change for a .1 patch release.
> usr/bin/__init__ is now also installed which not correct.
> Kind Regards,
> Bas
http://www.spatialys.com/
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
