[gdal-dev] GDAL 3.8.1 RC2 is available (was Re: GDAL 3.8.1 RC1 is available, and motion to approve it)
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Nov 27 08:45:56 PST 2023
+1 Javier
On Mon, 27 Nov 2023 at 17:30, Rahkonen Jukka via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> +1
> -Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Even
> Rouault via gdal-dev
> Lähetetty: perjantai 24. marraskuuta 2023 13.06
> Vastaanottaja: Sebastiaan Couwenberg <sebastic at xs4all.nl>;
> Aihe: [gdal-dev] GDAL 3.8.1 RC2 is available (was Re: GDAL 3.8.1 RC1 is
> Hi,
> OK, I've reverted that change. I'll guess someone will have to figure out
> how to have both .py scripts and .exe/.sh launchers at the same time...
> Pick up an archive among the following ones (by ascending size):
> Withdrawing previous motion and:
> Motion: adopt 3.8.1 RC2 as final 3.8.1 release
> Starting with my +1,
> Even
> Le 24/11/2023 à 06:34, Sebastiaan Couwenberg via gdal-dev a écrit :
> > On 11/23/23 22:56, Even Rouault via gdal-dev wrote:
> >>  From a packaging point of view, the following change might have
> >> impacts on build recipes:
> > The Python utilities are no longer installed with the .py extension,
> > this broke their use in QGIS when we removed this in the Debian
> > package some time ago. Don't know if that's still the case. Either
> > way, this doesn't seem like an appropriate change for a .1 patch release.
> > usr/bin/__init__ is now also installed which not correct.
> > Kind Regards,
> > Bas
> http://www.spatialys.com/
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231127/7bc0d826/attachment.htm>
