[gdal-dev] GDAL 3.8.1 RC1 is available, and motion to approve it
Hernán De Angelis variablestarlight at gmail.com
Fri Nov 24 04:22:35 PST 2023
May be this is of help: I have seen the case of the .py utilities not
been compiled and installed a couple of times when I mistakenly had two
Python versions present and acccessible.
/H.
Den 2023-11-24 kl. 13:16, skrev Even Rouault via gdal-dev:
> Bas,
>> The Python utilities are no longer installed with the .py extension,
>> this broke their use in QGIS when we removed this in the Debian
>> package some time ago. Don't know if that's still the case. Either
>> way, this doesn't seem like an appropriate change for a .1 patch
>> release.
> Are you sure about the .py utilities no longer be installed? Because,
> I see both /usr/bin/gdal2tiles and /usr/bin/gdal2tiles.py installed on
> Ubuntu 22.04 (before I reverted the change to add the launcher scripts)
> Even
