[gdal-dev] GDAL 3.8.1 RC1 is available, and motion to approve it
Sebastiaan Couwenberg sebastic at xs4all.nl
Fri Nov 24 05:32:38 PST 2023
On 11/24/23 13:16, Even Rouault via gdal-dev wrote:
>> The Python utilities are no longer installed with the .py extension,
>> this broke their use in QGIS when we removed this in the Debian
>> package some time ago. Don't know if that's still the case. Either
>> way, this doesn't seem like an appropriate change for a .1 patch release.
> Are you sure about the .py utilities no longer be installed? Because, I
> see both /usr/bin/gdal2tiles and /usr/bin/gdal2tiles.py installed on
> Ubuntu 22.04 (before I reverted the change to add the launcher scripts)
Both are installed indeed. I overlooked this when dh_missing failed on
the executables without extension.
Installing usr/bin/__init__ is still wrong though. Skipping __init__.py
when creating the console_scripts list may suffice.
Kind Regards,
Bas
  GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
