[gdal-dev] GDAL Java binding problem
Even Rouault even.rouault at spatialys.com
Mon Nov 27 05:17:54 PST 2023
Le 27/11/2023 à 10:40, Raivo Rebane via gdal-dev a écrit :
> Hi,
> I want to use GDAL for GML parsing with Java.
> I made an Eclipse project and got dependency - gdal-3.8.0.
> My code compiles fine, but in debuging at line - gdal.AllRegister();
> I got error :
> Native library load failed.
> java.lang.UnsatisfiedLinkError: no gdalalljni in java.library.path:
> [/home/Raivo/GML/lib]
> Exception in thread "main" java.lang.UnsatisfiedLinkError: 'void
> org.gdal.gdal.gdalJNI.AllRegister()'
> at org.gdal.gdal.gdalJNI.AllRegister(Native Method)
> at org.gdal.gdal.gdal.AllRegister(gdal.java:712)
> at My.Parser.Parser.main(Parser.java:16)
> an in realility gdalalljni doesnt exist in my computer.
> So I cloned GDAL sources from git, version 3.9.0, but I didn't find
> docs how to buil Java binding jar file
Cf
https://gdal.org/development/building_from_source.html#java-bindings-options
I've just submitted in https://github.com/OSGeo/gdal/pull/8836 more
detailed instructions:
How to use the bindings
The result of the build of the Java bindings will be both a :file:`gdal.jar`
and a companion :file:`libgdalalljni.so` / :file:`libgdalalljni.dylib` /
:file:`gdalalljni.dll` native library. To limit potential compatibility
problems,
you should ensure that gdal.jar and gdalalljni come from the same GDAL
sources.
The native gdalalljni library, as well as the core libgdal library (and its
dependencies) should be accessible through the mechanism of the operating
system to locate shared libraries.
Typically on Linux, this means that the path to those libraries should
be set
in the ``LD_LIBRARY_PATH`` environment variable (or in
:file:`/etc/ld.so.conf`).
On MacOSX, it should be in the ``DYLD_LIBRARY_PATH`` environment variable.
And on Windows, in the ``PATH`` environment variable.
For example, to test on Linux that the bindings are working, you can lanch,
from the build directory:
     export LD_LIBRARY_PATH=$PWD:$PWD/swig/java:$LD_LIBRARY_PATH
     java -classpath $PWD/swig/java/gdal.jar:$PWD/swig/java/build/apps
gdalinfo
On Windows:
     set PATH=%CD%;%CD%\swig\java;%PATH%
     java -classpath %CD%\swig\java\gdal.jar;%CD%\swig\java\build\apps
gdalinfo
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231127/cae722ad/attachment.htm>
