[gdal-dev] GDAL 3.8.1RC3 is available & motion to approve it
Javier Jimenez Shaw j1 at jimenezshaw.com
Tue Nov 28 09:52:42 PST 2023
+1 Javier
On Tue, 28 Nov 2023 at 17:29, Howard Butler via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> +1 Howard
> > On Nov 28, 2023, at 9:57 AM, Rahkonen Jukka via gdal-dev <
> > +1
> > -Jukka-
> > -----Alkuperäinen viesti-----
> > Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Even
> Rouault via gdal-dev
> > Lähetetty: tiistai 28. marraskuuta 2023 17.33
> > Vastaanottaja: gdal-dev at lists.osgeo.org
> > Aihe: [gdal-dev] GDAL 3.8.1RC3 is available & motion to approve it
> > Hi,
> > well, another annoying 3.8.0 regression related to ogr2ogr GPKG ->
> Shapefile when field names are longer than 10 characters (ah
> > Shapefile!!!) popped up today, so here's a RC3 (crossing fingers it's
> the good one):
> > A snapshot of the gdalautotest suite is also available:
> > The changes since RC2 are:
> > * CMake: make GDAL_USE_LIBKML and GDAL_USE_OPENJPEG honor
> GDAL_USE_EXTERNAL_LIBS
> > * Detect failure in installation of the Python bindings
> > * Fix installation issue with Python 3.12 on Debian
> > * GDALOverviewDataset::IRasterIO(): use parent dataset when possible for
> more
> >   efficiency
> > * gdal_footprint: fix wrong taking into account of alpha band (#8834)
> > * gdal_footprint: fix taking into account of individual bands that have
> nodata
> > * COG: for JPEG compression, convert single band+alpha as single band
> JPEG + 1-bit mask band
> > * GTIFF SRS reader: include VertCRS name from EPSG in CompoundCRS name
> if there's no citation geokey
> > * ogr2ogr: fix GPKG -> Shapefile when field names are truncated (#8849,
> > 3.8.0 regression)
> > * CSV writer: do not quote integer fields by default (only if
> STRING_QUOTING=ALWAYS is specified)
> > * GPX: make detection of extensions element more robust (#8827)
> > * Shapefile: recognize '      0' as a null date, fix writing an invalid
> "0000/00/00" date
> > * Python bindings: add a combineBands option to gdal.Footprint()
> > Withdrawing previous motion and:
> > ==> Motion: adopt 3.8.1 RC3 as final 3.8.1 release
> > Starting with my +1,
> > Even
> > My software is free, but my time generally not.
> > gdal-dev mailing list
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231128/20fa5bea/attachment-0001.htm>
