[gdal-dev] GDAL 3.8.1RC3 is available & motion to approve it
Sean Gillies sean.gillies at gmail.com
Tue Nov 28 10:23:16 PST 2023
I finally have configured a GitHub action that tests rasterio against the
latest GDAL tags and don't see any problems with 3.8.1RC3:
https://github.com/rasterio/rasterio/actions/runs/7022736307.
+1 for me
On Tue, Nov 28, 2023 at 8:32 AM Even Rouault via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> well, another annoying 3.8.0 regression related to ogr2ogr GPKG ->
> Shapefile when field names are longer than 10 characters (ah
> Shapefile!!!) popped up today, so here's a RC3 (crossing fingers it's
> the good one):
>    https://download.osgeo.org/gdal/3.8.1/gdal-3.8.1rc3.tar.xz
>    https://download.osgeo.org/gdal/3.8.1/gdal-3.8.1rc3.tar.gz
>    https://download.osgeo.org/gdal/3.8.1/gdal381rc3.zip
> A snapshot of the gdalautotest suite is also available:
> https://download.osgeo.org/gdal/3.8.1/gdalautotest-3.8.1rc3.tar.gz
>    https://download.osgeo.org/gdal/3.8.1/gdalautotest-3.8.1rc3.zip
> The changes since RC2 are:
> * CMake: make GDAL_USE_LIBKML and GDAL_USE_OPENJPEG honor
> GDAL_USE_EXTERNAL_LIBS
> * Detect failure in installation of the Python bindings
> * Fix installation issue with Python 3.12 on Debian
> * GDALOverviewDataset::IRasterIO(): use parent dataset when possible for
> more
>    efficiency
> * gdal_footprint: fix wrong taking into account of alpha band (#8834)
> * gdal_footprint: fix taking into account of individual bands that have
> nodata
> * COG: for JPEG compression, convert single band+alpha as single band
> JPEG + 1-bit mask band
> * GTIFF SRS reader: include VertCRS name from EPSG in CompoundCRS name
> if there's no citation geokey
> * ogr2ogr: fix GPKG -> Shapefile when field names are truncated (#8849,
> 3.8.0 regression)
> * CSV writer: do not quote integer fields by default (only if
> STRING_QUOTING=ALWAYS is specified)
> * GPX: make detection of extensions element more robust (#8827)
> * Shapefile: recognize '      0' as a null date, fix writing an invalid
> "0000/00/00" date
> * Python bindings: add a combineBands option to gdal.Footprint()
> Withdrawing previous motion and:
> ==> Motion: adopt 3.8.1 RC3 as final 3.8.1 release
> Starting with my +1,
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231128/39584df8/attachment.htm>
