[gdal-dev] GDAL driver Open() calls
Even Rouault even.rouault at spatialys.com
Tue Nov 28 15:36:00 PST 2023
Please share the stack trace (on a debug build) of both instances where
GDALOpen() is called
Even
Le 28/11/2023 à 23:40, Fengting Chen via gdal-dev a écrit :
> Hi,
> I noticed from the GeoRaster driver that in GDAL 3.6 and 3.7 (maybe
> 3.8 too),  there are two GDALOpen() calls on the driver with
> GDALOpenInfo eAccess as GA_ReadOnly, even when the GeoRaster is the
> output format in gdal_translate command. There are no such calls in
> GDAL 3.4. I am wondering if these invocations of Open() with eAccess
> as GA_ReadOnly are necessary when the driver is the output driver.
> This has caused performance issue for the GeoRaster driver when a user
> is trying to load the data into Oracle database because it has two
> unnecessary reads from the database.  If these Open() calls are
> unavoidable, how to differentiate the calls whether it is as input or
> as output in the gdal_translate command?
> Thanks.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231129/f496302f/attachment.htm>
