[gdal-dev] [EXTERNAL] Re: How to determine which creation options are supported by a driver?
Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] jesse.r.meyer at nasa.gov
Thu Nov 30 12:58:22 PST 2023
Thanks everyone, and congratulations on the 3.8 release.
Best,
Jesse
From: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
Date: Thursday, November 30, 2023 at 3:32 PM
To: "Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC]" <jesse.r.meyer at nasa.gov>, Even Rouault via gdal-dev <gdal-dev at lists.osgeo.org>
Subject: [EXTERNAL] Re: How to determine which creation options are supported by a driver?
CAUTION: This email originated from outside of NASA.  Please take care when clicking links or opening attachments.  Use the "Report Message" button to report suspicious messages to the NASA SOC.
Run ”gdalinfo –format GTiff”.  For me it prints:
<Option name="COMPRESS" type="string-select">
    <Value>NONE</Value>
    <Value>LZW</Value>
    <Value>PACKBITS</Value>
    <Value>JPEG</Value>
    <Value>CCITTRLE</Value>
    <Value>CCITTFAX3</Value>
    <Value>CCITTFAX4</Value>
    <Value>DEFLATE</Value>
    <Value>ZSTD</Value>
  </Option>
So my GDAL build does not support LERC.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] via gdal-dev
Lähetetty: torstai 30. marraskuuta 2023 22.19
Vastaanottaja: Even Rouault via gdal-dev <gdal-dev at lists.osgeo.org>
Aihe: [gdal-dev] How to determine which creation options are supported by a driver?
I have gdal 3.8.1 installed via Brew which includes liblerc and zstd as part of their formulae, so I assumed I could use the creation options “COMPRESS=LERC_ZSTD” and “MAX_Z_ERROR=x” as documented on the GTIFF page when creating a new gtif image.
But when I do GDAL states:
“Warning 6: 'LERC_ZSTD' is an unexpected value for COMPRESS creation option of type string-select.
Warning 6: driver GTiff does not support creation option MAX_Z_ERROR”
So I am not sure if this is an issue with the driver itself or with the brew formula.  Please advise,
Thanks,
Jesse
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231130/9f565b1c/attachment.htm>
