[gdal-dev] Questions regarding temporary database file (ogr2ogr with MVT driver)
Even Rouault
even.rouault at spatialys.com
Fri Oct 6 08:37:17 PDT 2023
>> You could possibly paralle
> Your text cut off at the interesting bit, could you elaborate on this @Even?
ah I meant you could parallelize generation on several machines, each
one with a different extent and/or zoom level
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231006/2d21517e/attachment.htm>
