[gdal-dev] OAPIF: how does the driver utilize schema?
Even Rouault
even.rouault at spatialys.com
Tue Oct 10 02:17:55 PDT 2023
Hi Jukka,
> The documentation in
> https://gdal.org/drivers/vector/oapif.html#layer-schema is wrong when
> it claims this:
> OGR needs a fixed schema per layer, but OGC API - Features Core
> doesn't impose fixed schema. So the driver will retrieve the first
> page of features (10 features) and establish a schema from this.
> I can see from the debug info and from the source code that if GDAL
> finds a relation of type “describedBy” for a collection then it reads
> and interprets the schema from the link. However, I am not sure if
> GDAL in this case trusts the schema and skips scanning of the first
> ten features for harvesting the attributes.
It doesn't fully trust the schema provided by describedBy and still
scans the first page of feature to complement it. Doc adjusted
> BTW, the name of the relation type has been changed into “describedby”
> due to https://github.com/opengeospatial/ogcapi-features/issues/338.
> It is better to support both describedBy and describedby.
Thanks. Fixed too (GDAL made case insensitive comparisons)
Even
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231010/aade33e1/attachment-0001.htm>
