[gdal-dev] help needed with pygdaltools library, documentation sparse
Catania, Luke A ERDC-RDE-GRL-VA CIV Luke.A.Catania at erdc.dren.mil
Tue Oct 10 22:59:03 PDT 2023
I have not even gotten to see that anything is being ignored because I have not yet added any options.  My first attempt was with adding skipfailures, but I can’t add any of the options I have listed because I have no idea how to.  I thought it would be gdal_tools.config_options() but I get pylint tells me it is not callable
-----Original Message-----
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Scott via gdal-dev
Sent: Wednesday, October 11, 2023 1:45 AM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] help needed with pygdaltools library, documentation sparse
-nln is being ignored because the data layer you're -updating -appending to exists. You can't rename a layer if it has a name. Remove -nln option
Next you are trying to write a collection as a linestring. Use -explodecollections (if exists in your install) and/or use -nlt PROMOTE_TO_MULTI
Try not to use -skipfailures
On 10/10/23 22:26, Catania, Luke A ERDC-RDE-GRL-VA CIV via gdal-dev wrote:
> I am running simple code to convert dxf to gpkg and I get the error
> below.  -am an trying to figure out how to add a bunch of options ( -f
> GPKG -append -update --config DXF_ENCODING CP1252 --config
> DXF_INCLUDE_RAW_CODE_VALUES TRUE --config
> DXF_TRANSLATE_ESCAPE_SEQUENCES FALSE --config
> DXF_MERGE_BLOCK_GEOMETRIES FALSE --config DXF_INLINE_BLOCKS TRUE -nlt
> LINESTRING -nln 32111_F)
> But can’t even figure out how to add the recommended skipfailures flag.
> I tried adding
> gdal_tools.config_options("-skipfailures")
> but I get pylint tells me it is not callable.
> Anyone use pygdaltools?  There is some documentation, but nothing
> showing you how to set these command line parameters.
> import gdaltools
> gdal_tools = gdaltools.ogr2ogr()
> gdal_tools.BASEPATH = r"C:\Program Files\QGIS 3.16.16\bin"
> gdal_tools.set_encoding("UTF-8")
> gdal_tools.set_input(self.dxf_out_path)
> gdal_tools.set_output(self.gpkg_out)
> gdal_tools.execute()
> And I get the ERROR:root:b"Warning 1: Layer creation options ignored
> since an existing layer is\r\n         being appended to.\r\nWarning 6:
> Normalized/laundered field name: 'EntityHandle' to
> 'EntityHa_2'\r\nERROR
> 1: Attempt to write non-linestring (GEOMETRYCOLLECTION) geometry to
> ARC type shapefile.\r\nERROR 1: Unable to write feature 0 from layer
> entities.\r\nERROR 1: Terminating translation prematurely after
> failed\r\ntranslation of layer entities (use -skipfailures to skip
> errors)\r\n"
> Traceback (most recent call last):
>    File
> "c:\Users\RDTECLAC\AppData\Roaming\QGIS\QGIS3\profiles\default\python\
> plugins\site_selection\tools\master_planning\load_mp_designs.py", line
> 227, in <module>
>      main()
>    File
> 196, in main
>      mp_designs.gdal_convert()
>    File
> 185, in gdal_convert
>    File
> "C:\Users\RDTECLAC\AppData\Roaming\Python\Python39\site-packages\gdalt
> ools\ogr2ogrcmd.py", line 330, in execute
>      return self._do_execute(args)
>    File
> ools\basetypes.py", line 108, in _do_execute
>      raise GdalToolsError(rc, err)
> gdaltools.basetypes.GdalToolsError: (1, b"Warning 1: Layer creation
> options ignored since an existing layer is\r\n         being appended
> to.\r\nWarning 6: Normalized/laundered field name: 'EntityHandle' to
> 'EntityHa_2'\r\nERROR 1: Attempt to write non-linestring
> (GEOMETRYCOLLECTION) geometry to ARC type shapefile.\r\nERROR 1:
> Unable to write feature 0 from layer entities.\r\nERROR 1: Terminating
> translation prematurely after failed\r\ntranslation of layer entities
> (use -skipfailures to skip errors)\r\n")error:
> gdal-dev mailing list
> Blockedhttps://lists.osgeo.org/mailman/listinfo/gdal-devBlocked
