[gdal-dev] layer.GetSpatialRef() fails on linux for shapefiles
Jonathan Moules jonathan-lists at lightpear.com
Wed Oct 11 06:18:00 PDT 2023
Hi List,
So, after more investigation:
* Using Python Anaconda on either Mac or Linux for GDAL (3.7.1),
`GetSpatialRef` triggers a RunTime Error for all shapefiles (but only
shapefiles).
* This happens on Ubuntu (two machines), and a Mac, but only under PyCharm.
* Using the exact same `conda` environment as triggers the above:
running it directly from the terminal works fine.
So there's something about the combination of conda and Pycharm that
breaks this aspect of GDAL shapefile handling on *nix and Mac.
Any thoughts? Also, who do I actually report this bug to? Is it GDAL,
Conda, Pycharm, something else?
Cheers,
Jonathan
On 2023-09-28 14:58, Jonathan Moules via gdal-dev wrote:
> Well, it seems that PROJ_DATA isn't set in their environment. But it's
> not set in mine either (`print(os.environ['PROJ_DATA']`)! So no idea
> why mine works just fine without it (Windows 11 thing?).
> Creating a PROJ_DATA env var didn't fix anything. Even adding it
> explicitly in Python.
> Their log file does have this in at a WARNING level:
> `PROJ: proj_create_from_database: Open of
> /home/user/anaconda3/envs/env1/share/proj failed`
> That path has: `drwxrwxr-x` permissions.
> To answer Even's earlier question:
> `ogrinfo /path/to/shape.shp` works fine on their system.
> On 2023-09-28 12:37, Rahkonen Jukka wrote:
>> Hi,
>> Then they should add that environment if they do not know that they
>> do not belong to "most users"
>> https://proj.org/en/9.3/usage/environmentvars.html
>> -Jukka Rahkonen-
>> -----Alkuperäinen viesti-----
>> Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta
>> Lähetetty: torstai 28. syyskuuta 2023 14.10
>> Vastaanottaja: gdal-dev at lists.osgeo.org; Even Rouault
>> <even.rouault at spatialys.com>
>> Aihe: Re: [gdal-dev] layer.GetSpatialRef() fails on linux for shapefiles
>> Hi Even,
>> The colleague doesn't have either a PROJ_LIB or a PROJ_DATA
>> environment variable.
>> I asked another colleague to try it; they're on Ubuntu 20.04, and it
>> worked for them. I believe using the same setup instructions.
>> Cheers,
>> Jonathan
>> On 2023-09-24 22:37, Jonathan Moules via gdal-dev wrote:
>>> Thanks Even. I don't have access to the machine either as the
>>> colleague is moving to another project. I'll have to see if it fails
>>> for another *nix user.
>>> On 2023-09-24 22:35, Even Rouault wrote:
>>>> Le 24/09/2023 à 23:22, Jonathan Moules via gdal-dev a écrit :
>>>>>> Also check if the environment isn't messed up regarding PROJ and
>>>>> the PROJ_LIB/PROJ_DATA environment variable
>>>>> Thanks Even; sorry, what does this line mean? I'm guessing you're
>>>>> referring to:
>>>>> https://proj.org/en/9.3/usage/environmentvars.html - what would a
>>>>> "messed up" one look like?
>>>> Hard to say without access to the machine. Perhaps just try to
>>>> recreate a new Conda env from scratch
>>> gdal-dev mailing list
>>> https://list/
>>> s.osgeo.org%2Fmailman%2Flistinfo%2Fgdal-dev&data=05%7C01%7Cjukka.rahko
>>> nen%40maanmittauslaitos.fi%7C1f6517888cb34fa40aed08dbc01389dd%7Cc4f8a6
>>> 3255804a1c92371d5a571b71fa%7C0%7C0%7C638314962370381350%7CUnknown%7CTW
>>> FpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6
>>> Mn0%3D%7C3000%7C%7C%7C&sdata=3fVru6K6Ndpkv35FnAbMOlT%2BM96USO7wywqx550
>>> uRUs%3D&reserved=0
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
