[gdal-dev] help needed with pygdaltools library, documentation sparse
Catania, Luke A ERDC-RDE-GRL-VA CIV Luke.A.Catania at erdc.dren.mil
Wed Oct 11 11:28:54 PDT 2023
I am running  GDAL 3.4.1, released 2021/12/27
I don’t need the fill style as I can fill that with code, just need the geometry.
I added it though not really sure what value to use. Based on the current options I used --config DXF_HATCH_TOLERANCE value vs --config DXF_HATCH_TOLERANCE=value as the latter gives me an error. My full options are:
"-f GPKG --config DXF_ENCODING CP1252 --config DXF_HATCH_TOLERANCE 5 --config DXF_INCLUDE_RAW_CODE_VALUES TRUE --config DXF_TRANSLATE_ESCAPE_SEQUENCES FALSE --config DXF_MERGE_BLOCK_GEOMETRIES FALSE --config DXF_INLINE_BLOCKS TRUE -nlt geometry"
I tried values of 1, 5, 10, 50 and do not get anything.  Maybe something else in my parameters are incorrect.  I was not really sure what to use for some of the parameters, but found this parameter string on another forum and it worked for most of my needs other than the issue with the hatches not converting properly and missing symbology for the geometry.
-----Original Message-----
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Scott via gdal-dev
Sent: Wednesday, October 11, 2023 2:07 PM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] help needed with pygdaltools library, documentation sparse
What version of ogr2ogr are you using?
Look at the .dxf driver page:
Blockedhttps://gdal.org/drivers/vector/dxf.htmlBlocked
HATCH: Line and arc boundaries are collected as a polygon geometry, but no effort is currently made to represent the fill style of HATCH entities. Behavior is affected by the following configuration option:
     DXF_HATCH_TOLERANCE=value: Determines the tolerance used when looking for the next component to add to the hatch boundary.
(GDAL <= 2.2.x) Only line and polyline boundary paths are translated correctly.
On 10/11/23 10:51, Catania, Luke A ERDC-RDE-GRL-VA CIV wrote:
> I went with calling ogr2ogr through os.system, but another issue I have
> been having with the ogr2ogr is that my polygons are not converted to
> what I guess is considered in AutoCAD as hatches since that is the layer
> that is shown for those polygons when I open the DXF. I just get line
> features.  It basically creates a line feature out of the polygon, that
> is it  converts the triangle to a bisecting line.  I even specify the
> *polygon* in the command line options as opposed to *linestring* as well
> as tried just the *geometry* parameter you suggested and writing to a
> geopackage
> DXF shown in DWG TrueView 2023
> Blockedhttps://pasteboard.co/dit2y9zmJ5YT.pngBlocked
> <Blockedhttps://pasteboard.co/dit2y9zmJ5YT.pngBlocked>
> DXF Converted by QGIS tool Import Layers from DWG/DXF
> Blockedhttps://pasteboard.co/4XZwHus6NhAj.pngBlocked
> <Blockedhttps://pasteboard.co/4XZwHus6NhAj.pngBlocked>
> DXF Converted to Geopackage.
> Blockedhttps://pasteboard.co/1wIMI9xRymkZ.pngBlocked
> <Blockedhttps://pasteboard.co/1wIMI9xRymkZ.pngBlocked>
> From: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi
> <mailto:jukka.rahkonen at maanmittauslaitos.fi>>
> Sent: Wednesday, October 11, 2023 2:12 AM
> To: Catania, Luke A ERDC-RDE-GRL-VA CIV <Luke.A.Catania at erdc.dren.mil
> <mailto:Luke.A.Catania at erdc.dren.mil>>; Scott <public at postholer.com
> <mailto:public at postholer.com>>; gdal-dev at lists.osgeo.org
> <mailto:gdal-dev at lists.osgeo.org>
> Hi,
> The actual error seems to be that you try to write some geometry that is
> not a linestring into a GeoPackage table that has created with a
> constraint that makes it accept only linestrings. You do that by using
> "-nlt linestring".
> You have two options. The fast one is to use "-nlt geometry" that makes
> GeoPackage table to accept all kind of geometries. The other option is
> to filter the source data by geometry type and select only linestrings.
> Here is an example about how to do that with the OGR SQL dialect
> Blockedhttps://gdal.org/user/ogr_sql_dialect.html#ogr-geometryBlocked
> Don't try to use "-nlt geometry" with shapefiles because that format
> does not support mixed geometrytypes.
> -Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org
> <mailto:gdal-dev-bounces at lists.osgeo.org>> Puolesta Catania, Luke A
> ERDC-RDE-GRL-VA CIV via gdal-dev
> Lähetetty: keskiviikko 11. lokakuuta 2023 8.59
> Vastaanottaja: Scott <public at postholer.com
> Aihe: Re: [gdal-dev] help needed with pygdaltools library, documentation
> sparse
> I have not even gotten to see that anything is being ignored because I
> have not yet added any options.  My first attempt was with adding
> skipfailures, but I can't add any of the options I have listed because I
> have no idea how to.  I thought it would be gdal_tools.config_options()
> but I get pylint tells me it is not callable
> <mailto:gdal-dev-bounces at lists.osgeo.org>> On Behalf Of Scott via gdal-dev
> Sent: Wednesday, October 11, 2023 1:45 AM
> To: gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> -nln is being ignored because the data layer you're -updating -appending
> to exists. You can't rename a layer if it has a name. Remove -nln option
> Next you are trying to write a collection as a linestring. Use
> -explodecollections (if exists in your install) and/or use -nlt
> PROMOTE_TO_MULTI
> Try not to use -skipfailures
> On 10/10/23 22:26, Catania, Luke A ERDC-RDE-GRL-VA CIV via gdal-dev wrote:
>  > I am running simple code to convert dxf to gpkg and I get the error
>  > below.  -am an trying to figure out how to add a bunch of options ( -f
>  > GPKG -append -update --config DXF_ENCODING CP1252 --config
>  > LINESTRING -nln 32111_F)
>  > But can't even figure out how to add the recommended skipfailures flag.
>  > I tried adding
>  > gdal_tools.config_options("-skipfailures")
>  > but I get pylint tells me it is not callable.
>  > Anyone use pygdaltools?  There is some documentation, but nothing
>  > showing you how to set these command line parameters.
>  > import gdaltools
>  > gdal_tools = gdaltools.ogr2ogr()
>  > gdal_tools.BASEPATH = r"C:\Program Files\QGIS 3.16.16\bin"
>  > gdal_tools.set_encoding("UTF-8")
>  > gdal_tools.set_input(self.dxf_out_path)
>  > gdal_tools.set_output(self.gpkg_out)
>  > gdal_tools.execute()
>  > And I get the ERROR:root:b"Warning 1: Layer creation options ignored
>  > since an existing layer is\r\n         being appended to.\r\nWarning 6:
>  > Normalized/laundered field name: 'EntityHandle' to
>  > 'EntityHa_2'\r\nERROR
>  > 1: Attempt to write non-linestring (GEOMETRYCOLLECTION) geometry to
>  > ARC type shapefile.\r\nERROR 1: Unable to write feature 0 from layer
>  > entities.\r\nERROR 1: Terminating translation prematurely after
>  > failed\r\ntranslation of layer entities (use -skipfailures to skip
>  > errors)\r\n"
>  > Traceback (most recent call last):
>  >    File
>  > "c:\Users\RDTECLAC\AppData\Roaming\QGIS\QGIS3\profiles\default\python\
>  > plugins\site_selection\tools\master_planning\load_mp_designs.py", line
>  > 227, in <module>
>  >      main()
>  >    File
>  > 196, in main
>  >      mp_designs.gdal_convert()
>  >    File
>  > 185, in gdal_convert
>  >    File
>  > "C:\Users\RDTECLAC\AppData\Roaming\Python\Python39\site-packages\gdalt
>  > ools\ogr2ogrcmd.py", line 330, in execute
>  >      return self._do_execute(args)
>  >    File
>  > ools\basetypes.py", line 108, in _do_execute
>  >      raise GdalToolsError(rc, err)
>  > gdaltools.basetypes.GdalToolsError: (1, b"Warning 1: Layer creation
>  > options ignored since an existing layer is\r\n         being appended
>  > to.\r\nWarning 6: Normalized/laundered field name: 'EntityHandle' to
>  > 'EntityHa_2'\r\nERROR 1: Attempt to write non-linestring
>  > (GEOMETRYCOLLECTION) geometry to ARC type shapefile.\r\nERROR 1:
>  > Unable to write feature 0 from layer entities.\r\nERROR 1: Terminating
>  > translation prematurely after failed\r\ntranslation of layer entities
>  > (use -skipfailures to skip errors)\r\n")error:
>  > _______________________________________________
>  > gdal-dev mailing list
>  > Blockedhttps://eur06.safelinks.protection.outlook.com/?url=https%3A%2F
>  > %2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgdal-devBlocked&data=05%7C01
>  > %7Cjukka.rahkonen%40maanmittauslaitos.fi%7C476e640a44f14b283ee008dbca1
>  > f38eb%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C638326007673488940%
>  > 7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik
>  > 1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=n2JmJTKxfldyTjy08p5bXOtMxMn
>  > Zw7iy2EwIYpfMnc4%3D&reserved=0
> Blockedhttps://lists.osgeo.org/mailman/listinfo/gdal-devBlocked
