[gdal-dev] help needed with pygdaltools library, documentation sparse
Scott public at postholer.com
Wed Oct 11 11:06:47 PDT 2023
What version of ogr2ogr are you using?
Look at the .dxf driver page:
https://gdal.org/drivers/vector/dxf.html
HATCH: Line and arc boundaries are collected as a polygon geometry, but
no effort is currently made to represent the fill style of HATCH
entities. Behavior is affected by the following configuration option:
     DXF_HATCH_TOLERANCE=value: Determines the tolerance used when
looking for the next component to add to the hatch boundary.
(GDAL <= 2.2.x) Only line and polyline boundary paths are translated
correctly.
On 10/11/23 10:51, Catania, Luke A ERDC-RDE-GRL-VA CIV wrote:
> I went with calling ogr2ogr through os.system, but another issue I have
> been having with the ogr2ogr is that my polygons are not converted to
> what I guess is considered in AutoCAD as hatches since that is the layer
> that is shown for those polygons when I open the DXF. I just get line
> features.  It basically creates a line feature out of the polygon, that
> is it  converts the triangle to a bisecting line.  I even specify the
> *polygon* in the command line options as opposed to *linestring* as well
> as tried just the *geometry* parameter you suggested and writing to a
> geopackage
> DXF shown in DWG TrueView 2023
> https://pasteboard.co/dit2y9zmJ5YT.png
> <https://pasteboard.co/dit2y9zmJ5YT.png>
> DXF Converted by QGIS tool Import Layers from DWG/DXF
> https://pasteboard.co/4XZwHus6NhAj.png
> <https://pasteboard.co/4XZwHus6NhAj.png>
> DXF Converted to Geopackage.
> https://pasteboard.co/1wIMI9xRymkZ.png
> <https://pasteboard.co/1wIMI9xRymkZ.png>
> -----Original Message-----
> From: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi
> <mailto:jukka.rahkonen at maanmittauslaitos.fi>>
> Sent: Wednesday, October 11, 2023 2:12 AM
> To: Catania, Luke A ERDC-RDE-GRL-VA CIV <Luke.A.Catania at erdc.dren.mil
> <mailto:Luke.A.Catania at erdc.dren.mil>>; Scott <public at postholer.com
> <mailto:public at postholer.com>>; gdal-dev at lists.osgeo.org
> <mailto:gdal-dev at lists.osgeo.org>
> Subject: Re: [gdal-dev] help needed with pygdaltools library,
> Hi,
> The actual error seems to be that you try to write some geometry that is
> not a linestring into a GeoPackage table that has created with a
> constraint that makes it accept only linestrings. You do that by using
> "-nlt linestring".
> You have two options. The fast one is to use "-nlt geometry" that makes
> GeoPackage table to accept all kind of geometries. The other option is
> to filter the source data by geometry type and select only linestrings.
> Here is an example about how to do that with the OGR SQL dialect
> Blockedhttps://gdal.org/user/ogr_sql_dialect.html#ogr-geometryBlocked
> Don't try to use "-nlt geometry" with shapefiles because that format
> does not support mixed geometrytypes.
> -Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org
> <mailto:gdal-dev-bounces at lists.osgeo.org>> Puolesta Catania, Luke A
> ERDC-RDE-GRL-VA CIV via gdal-dev
> Lähetetty: keskiviikko 11. lokakuuta 2023 8.59
> Vastaanottaja: Scott <public at postholer.com
> Aihe: Re: [gdal-dev] help needed with pygdaltools library, documentation
> sparse
> I have not even gotten to see that anything is being ignored because I
> have not yet added any options.  My first attempt was with adding
> skipfailures, but I can't add any of the options I have listed because I
> have no idea how to.  I thought it would be gdal_tools.config_options()
> but I get pylint tells me it is not callable
> From: gdal-dev <gdal-dev-bounces at lists.osgeo.org
> <mailto:gdal-dev-bounces at lists.osgeo.org>> On Behalf Of Scott via gdal-dev
> Sent: Wednesday, October 11, 2023 1:45 AM
> To: gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> -nln is being ignored because the data layer you're -updating -appending
> to exists. You can't rename a layer if it has a name. Remove -nln option
> Next you are trying to write a collection as a linestring. Use
> -explodecollections (if exists in your install) and/or use -nlt
> PROMOTE_TO_MULTI
> Try not to use -skipfailures
> On 10/10/23 22:26, Catania, Luke A ERDC-RDE-GRL-VA CIV via gdal-dev wrote:
>  > I am running simple code to convert dxf to gpkg and I get the error
>  > below.  -am an trying to figure out how to add a bunch of options ( -f
>  > GPKG -append -update --config DXF_ENCODING CP1252 --config
>  > DXF_INCLUDE_RAW_CODE_VALUES TRUE --config
>  > DXF_TRANSLATE_ESCAPE_SEQUENCES FALSE --config
>  > DXF_MERGE_BLOCK_GEOMETRIES FALSE --config DXF_INLINE_BLOCKS TRUE -nlt
>  > LINESTRING -nln 32111_F)
>  > But can't even figure out how to add the recommended skipfailures flag.
>  > I tried adding
>  > gdal_tools.config_options("-skipfailures")
>  > but I get pylint tells me it is not callable.
>  > Anyone use pygdaltools?  There is some documentation, but nothing
>  > showing you how to set these command line parameters.
>  > import gdaltools
>  > gdal_tools = gdaltools.ogr2ogr()
>  > gdal_tools.BASEPATH = r"C:\Program Files\QGIS 3.16.16\bin"
>  > gdal_tools.set_encoding("UTF-8")
>  > gdal_tools.set_input(self.dxf_out_path)
>  > gdal_tools.set_output(self.gpkg_out)
>  > gdal_tools.execute()
>  > And I get the ERROR:root:b"Warning 1: Layer creation options ignored
>  > since an existing layer is\r\n         being appended to.\r\nWarning 6:
>  > Normalized/laundered field name: 'EntityHandle' to
>  > 'EntityHa_2'\r\nERROR
>  > 1: Attempt to write non-linestring (GEOMETRYCOLLECTION) geometry to
>  > ARC type shapefile.\r\nERROR 1: Unable to write feature 0 from layer
>  > entities.\r\nERROR 1: Terminating translation prematurely after
>  > failed\r\ntranslation of layer entities (use -skipfailures to skip
>  > errors)\r\n"
>  > Traceback (most recent call last):
>  >    File
>  > "c:\Users\RDTECLAC\AppData\Roaming\QGIS\QGIS3\profiles\default\python\
>  > plugins\site_selection\tools\master_planning\load_mp_designs.py", line
>  > 227, in <module>
>  >      main()
>  >    File
>  > 196, in main
>  >      mp_designs.gdal_convert()
>  >    File
>  > 185, in gdal_convert
>  >    File
>  > "C:\Users\RDTECLAC\AppData\Roaming\Python\Python39\site-packages\gdalt
>  > ools\ogr2ogrcmd.py", line 330, in execute
>  >      return self._do_execute(args)
>  >    File
>  > ools\basetypes.py", line 108, in _do_execute
>  >      raise GdalToolsError(rc, err)
>  > gdaltools.basetypes.GdalToolsError: (1, b"Warning 1: Layer creation
>  > options ignored since an existing layer is\r\n         being appended
>  > to.\r\nWarning 6: Normalized/laundered field name: 'EntityHandle' to
>  > 'EntityHa_2'\r\nERROR 1: Attempt to write non-linestring
>  > (GEOMETRYCOLLECTION) geometry to ARC type shapefile.\r\nERROR 1:
>  > Unable to write feature 0 from layer entities.\r\nERROR 1: Terminating
>  > translation prematurely after failed\r\ntranslation of layer entities
>  > (use -skipfailures to skip errors)\r\n")error:
>  > _______________________________________________
>  > gdal-dev mailing list
>  > Blockedhttps://eur06.safelinks.protection.outlook.com/?url=https%3A%2F
>  > %2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgdal-devBlocked&data=05%7C01
>  > %7Cjukka.rahkonen%40maanmittauslaitos.fi%7C476e640a44f14b283ee008dbca1
>  > f38eb%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C638326007673488940%
>  > 7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik
>  > 1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=n2JmJTKxfldyTjy08p5bXOtMxMn
>  > Zw7iy2EwIYpfMnc4%3D&reserved=0
> Blockedhttps://lists.osgeo.org/mailman/listinfo/gdal-devBlocked
