[gdal-dev] including higher-level library in GPX creator string
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Fri Oct 13 07:40:27 PDT 2023
It seems to be hardcoded in https://github.com/OSGeo/gdal/blob/2cfeb1a9b03716c8348d6f1f4c611f2589d53e76/ogr/ogrsf_frmts/gpx/ogrgpxdatasource.cpp#L744
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Greg Troxel via gdal-dev
Lähetetty: perjantai 13. lokakuuta 2023 15.52
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] including higher-level library in GPX creator string
I am a member of the GPX standards list, and we are discussing a new version and also dealing with broken data.
I wrote a gpx (from geojson), with just ogr2ogr, and the creator looks like this:
  creator="GDAL 3.5.3"
that's arguably totally fine with ogr2ogr.
But it seems that if some random big program links with gdal and uses it to produce a file, the creator is just GDAL, and not "qgis 3.28.5 via GDAL 3.5.3" or something like that.  I groveled over all my gpx files and found none that indicated anything like this.
It would be helpful to the GPX community if files were attributed to the larger software as well, so that they can be chased down or at least understood to be separately broken.
I don't see anything at
<link removed because our mail system made it so strange>
that could be used to do this.
Does this make sense to people here?
Is there any facility that would do this, that people just aren't using?
Any other thoughts?
Greg
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
