[gdal-dev] Notice: issue about multi-threaded GTiff compression+decompression
Kurt Schwehr schwehr at gmail.com
Mon Oct 16 08:14:14 PDT 2023
Thanks for the heads up!
Can you share that SHAs of the fix and cause?
On Mon, Oct 16, 2023, 7:44 AM Even Rouault via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> For GDAL 3.6.0 to 3.7.2, use of multi-threaded GTiff
> compression+decompression, in particular within the same file, as for
> example in a "gdalwarp -co COMPRESS=... -co NUM_THREADS=..." workflow
> can lead to deadlocks (process stalled forever) and/or data corruption
> (sometimes without errors at generation). Cf
> https://github.com/OSGeo/gdal/issues/8470 for a reproducer. The fix is
> in https://github.com/OSGeo/gdal/pull/8561
> The issue is particularly visible on Windows, or more generally any
> operating system (or file system where the output file is located) which
> has no VSIVirtualHandle::PRead() implementation, but it can also be
> occasionally reproduced on Linux (at least as a deadlock).
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231016/dc9584b2/attachment-0001.htm>
